thanks guys so much for the help. i really think i'll be fine with fat kinetik. im not the type of guy to sit around and blast music or do demos, so hopefully it will all work out.
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
You're sure the Monte only has an eighty amp alt?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
nononononoooo haha the monte has a 140 i think. this is for a 2001 celica gt, buying it next month
1999 Monte Carlo
Sony CDX-GT34w
i know how to hook up a volt meter no problem, but how do i go about running it on the dash, when i wanna see what the AMP'S EXACT voltage is? i dont wanna just hook it up to a 12v wire up front...
1999 Monte Carlo
Sony CDX-GT34w
Go with XS over Kinetik if ya can afford it! Just my $0.02
Should be good w stock 80 amp alt and under 2k rms
Monitor it with either a digital multimeter or a volt meter - if ya see dropping you could always up the alt to a better alt ( like someone said before make sure it has a good low rpm output )
Youll be fine bro!
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
I'd do a D3100 in the rear OR D3400 upfront with a D975 or whatever the smallest XS battery is in the rear... There's near a 40A difference between our Alts, so I'd try and make up that difference with an extra battery or larger battery...
Aah. Reading > Me. lol
Just run the volt meter to the back. Tie the wires in with the amplifier. Your voltage shouldn't be off by more than .1 or so. Just make sure you adjust the volt meter with a known good DMM when you get it.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
thanks bj, you the man. this is gonna be fun fitting power wires, line driver jumpers, and volt meter wires all into the same terminals!
1999 Monte Carlo
Sony CDX-GT34w
  • Who's Online   1 Member, 0 Anonymous, 1356 Guests (See full list)
