2011 Chevy Tahoe, 10k watts, 4 Fi BTL 15s, 4 DC Power alts!
No more comments? After it's all done? :) I know I know, you're all waiting for videos. I got the camera (Panasonic HDC-TM90), and am getting an external mike Thursday. I will be taking the bass to the max by this weekend, and will for sure have videos. I am curious to see if this gets as loud as I expect (based on how loud it gets at lower volumes), if not we'll have to figure out together WTF is going on.
Should be pretty loud. I have done a 50 with just 2k. I would like to see some numbers from this
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
you seem young but know ALOT OF SHT!
over all great build, pics and explanation
diggin the door pods
on the amp rack, is there a reason why u went with that kinda of amp rack instead of stacking them on top of each other with some room in between?
not sure if i missed it but where did u get ur wire from? how u like it so far...looks just like the stuff i got fro my teg "power werx welding cable"
This is AWESOME!! And yes now vids please lol. Congratulations on the completion!
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Guest DC Power Kyle
So,
Voltage readings!
Idle and at 2k? at full tilt? :)
those alts look great. My favorite part is the doors. They look amazing. Need vids popcorn.gif
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Nice work! The DC Power panel looks good, but it's almost missing something. Like maybe, LIGHTS THAT'S IT! Here's my suggestion! Make a wooden frame for it, and resin it so it will withstand the elements. Router out the back of the frame so the panel will sit in it, and enough room for some led strips to wrap around the edge of it. Then put some duct tape on the back to seal in the light. Then, paint the frame the red color to match! GOLDEN! You could even put it on the hood switch for the hood light and then it only comes on when you lift the hood! :drink40:
I like the re route job though too. You say one zip tie, I think the only place I see that could use one is right behind the last amp before the sub box. They kind of spread there. Otherwise I think you did a killer job! Big props man! :yahoo:
The logo looks sick over the fan shroud, what if u just painted the back side of it black? The letters will stand out better, it hides the upper radiator hose under it, and it won't require any further modification... Just a thought
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
That's the only time I can really rail on mine. Plus voltage is golden. Speaking of how's yours full tilt?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
