2011 Chevy Tahoe, 10k watts, 4 Fi BTL 15s, 4 DC Power alts!
If you put a smaller belt on there, or changed pulleys to increase tension to where the tensioner is at max tension at resting, you will burn up bearing. I have done it on my sierra.
Edit: Watched your video, that noise from the motor, that is the alts pulling the engine down to like 300 rpm and almost stalling you out, my truck does same thing. If I do a hard clipped burp, and then pause you can hear my rpm recover and the engine make that clucking sound. Give it some gas and it won't do that.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Guest DC Power Kyle
Yeah, our bearings are very very strong. If you end up getting a smaller HD belt to fit, let us know... You can also try the Racing Belts that are blue (They end in RB instead of HD) But I really really doubt you'll find something smaller that will "fit". If you can shoot me a video like i said above that can give me a better idea of what's going on.
If i remember right, I remember someone saying that there is a hole on the throttle body valve and can drill it out a little bigger than factory and it will help with the engine to keep the rpms up when the engine is idling with the 4 alts pulling down the engine. Not sure if it will work, but remember somewhere someone saying that. Not sure if you want to go that route but just an idea.
formerly known as Blue86f150
this sux camel dicks
this is one of the best tahoe builds ive seen in awhile (besides steves). great job :clapping:
2001 vw gti
2 hds212s
4.75 net tuned to 34hz
audioque1200 wired to 1 ohm
nvx 0 gauge to the back
kinetic khc 2000
kenwood deck
Sounds kind of dangerous... but since idle is ECU-controlled on this truck I imagine I could ask Justin at BlackBearPerformance to give me a tune for my AutoCal to adjust idle upwards. I would use that tune file only for demos/shows, otherwise it would murder my gas mileage (even more than it's already been murdered).
Right now the tensioner antics/squeal when accelerating is a bigger concern...
Goodluck with solving the squeak on hard acceleration or shifts. I've had dual now triples on mine and have been trying to solve that's issues for years. Its all dependant on the tensioner imo.
I've changed pulley sizes, belt lengths ,added idlers ,changed tensioner with new one. And still have squeak
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I won't quote Kyles post but my god that is some amazing customer service. I can't wait till we have such dedicated and passionate alternator people over in the UK.
Daniel Brill-Edwards - Representing English Bassheads!!
Old Build Log - http://www.stevemeadedesigns.com/board/topic/94637-vw-golf-mk3-1996-build-from-england/
New build coming soon with SMD V1 #99
YouTube Channel - http://www.youtube.com/brilledwards
You are beating a dead horse, everyone who has a quad kit that I have talked to in person has belt squeal the belt is too long and to fix it you need a secondary tensioner by the alts.
Evo X build log
If you find a stronger tensioner let me know. My local shops aren't helpful.. I know they are out there irragi used one on 6 alts before his demise...
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Go to a race performance type shop and ask there or better yet one that actually does work on newer vehicles (performance wise). If you have trouble finding one, one of the easiest ways to find real shops (when I say real I mean ones where they have cars that race funny/outlaw/etc) is to look for a local Powermaster retailer.
I suggest a real race shop because if they can make a car do 220 in the quarter I'm sure they can handle some belt slip ;) If you were around here I would tell you where to go, but Livernois Engineering/Detroit Speed Shop isn't exactly local for you...
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
