toadking90 Posted July 13, 2011 Report Posted July 13, 2011 Ok so I have my ground coming off my amp and going into a stinger dual foot ground post. I have that bolted onto the metal of the floor of my truck. It's metal to metal I worked hard on making it shinny just wanted to make sure that's acceptable. If not please give me a better way. Thanks Quote
RickyFriery97 Posted July 13, 2011 Report Posted July 13, 2011 drill a hole and use a grommet and run the ground under the truck directly to a clean place on the frame Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
mr.p Posted July 13, 2011 Report Posted July 13, 2011 The best ground is something firm but not too soft. When grounding i prefer limestone type of terrain over mud or concrete. Where do you ground? I ground like this ; Quote DCAUDIO BALLS DEEP
toadking90 Posted July 13, 2011 Author Report Posted July 13, 2011 Lol thanks guys. Ok and exactly how do I mount it to the frame? Not trying to ask dumb questions. Just want to be able to do it right when I do. Quote
Rebel4055 Posted July 13, 2011 Report Posted July 13, 2011 (edited) Drill a hole in the frame, grind the paint off, put a long enough bolt through it, nut and washer the ground wire to it. Edited July 13, 2011 by Rebel4055 Quote Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
ChevyBoy95 Posted July 13, 2011 Report Posted July 13, 2011 what you did is perfectly fine. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
taylorpro Posted July 13, 2011 Report Posted July 13, 2011 (edited) i drilled a hole straight through my frame rail and through-bolted it Edited July 13, 2011 by taylorpro Quote 1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
