Ok ive figured out most everything so far... but now im down to a couple more wires...
1: I have 2 black wires coming out of wire harness(ground) 1 has a terminal the other does not... do i ground them both?
2: The plug in to the Head unit has 1 black cable coming out of it with terminal.. can i just cut terminal off and hook it to the harness and then get rid of the terminal one on the harness?
3: Where does the Dimmer ground go? It is on the wire harness but not on the head unit harness.
4: How do i find where to hook my Parking break wire that is on head unit harness?
Going to edit first post so these are the only questions. t spot to ground while your in the head unit area?
Edited by dkahns51
You can tap into the cig lighter for a constant power if one is near the H/U or what said about the fuse block for one. Any place that has metal under the dash for a grounding location.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I dont have a cig lighter but i do have the thing to charge phones and what not...
if your charger stays on with the car off, then that will work
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
Edited by dkahns51
ill help you with the last one #4, ground that wire to the wiring harness ground so that you can watch videos as you drive. its suppose to be a safety feature but whats the fun in that.
