I have a 97 civic that is obd2 wiring. well anyways it came stock with a d16y8. I bought a complete b16 swap which of course i dont expect everything to be there. but the guy threw in two obd1 vtec ecus and said they would plug right in. and i knew it couldnt be that easy. sure enough they didnt. so i would either need a obd2 to obd1 conversion harness or just get the obd2 ecu correct? but even after that how would i get the vtec part of it to work?
1995 Integra GSR (DB8)
Pioneer 3200-DVD
6.5 rockford fosgate 2-way fronts
6.5 rockford fosgate 3-way rear
saz-3000D
(2) 12" SA-12s
Yeah you just need the obd1 to obd2 wiring. Then for the vtec part just take it to a mechanic if you dont know what your doing. Then you have someone to blame if something goes wrong lol. I have a 92 prelude with an H23A in it but then i swapped an H22A VTEC into it. Good luck! :drinks:
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
I personally always ran OBD1 on my swapped Honda's, just a personal preference I guess. As for VTEC if your having problems you can always run it off an RPM activated switch and make it engage whenever you want. 4,400-4,600 is where I usually had mine set in the tune.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
ur harness is obd2a thats the 96-98 harness i would get the obd2a-obd1 conversion for it cus an obd1 ecu is always nicer and make sure ur running a p28 ecu its the gsr ecu... as for vtec u can wire that into the ecu... i have a 96 civic hatch with ls/vtec if u have any other problems message me i'll help ya out
You need to check into your smog laws, you may just want to convert to an OBDII for that. If not, OBD1 is a better way to go.
Clovis Custom Audio 559-392-3600
96 Silverado Single Cab
2-DD9515's Cut-through
1-DDSE Amp
Stock electrical and a couple small stingers, LOL
