KnockinthaStreetzof608 Posted July 18, 2011 Report Share Posted July 18, 2011 well i currently have 2d3100s in my trunk and one 3400 under the hood and 1mechman 270 in my car and when with the car off its 12.6-12.8 all depends if i charge my batterys or not on my xspowercharger1215 and when the car is on around 13.6 very rarley see it go past 14volts even when im driving and dont play my system for 10-15mins any help? i would like to add more power but i fear huge voltage drop i run a aq3500d1 and plan on running 2 sundown3500s really soon also car is a 05ford mustang Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
THEKINGsBACK Posted July 18, 2011 Report Share Posted July 18, 2011 is the big 3 done... check grounds... with that type of electrical you should be solid on a aq 3500.1 unless your running a dumb low ohm load.. Quote he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick: Link to comment Share on other sites More sharing options...
tonedeaf Posted July 18, 2011 Report Share Posted July 18, 2011 The xs vcm as boiler said...you can set your alt to charge @ whatever you want. Quote Link to comment Share on other sites More sharing options...
Louisiana Bass Posted July 18, 2011 Report Share Posted July 18, 2011 I'm having the same problem, but with stock alt and XS D3400 under hood w/ big 3. My truck stays at 13.6-13.7 when driving, with no amps connected. Is it just something that some vehicles have that cause it to stay at that level? Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted July 18, 2011 Author Report Share Posted July 18, 2011 is the big 3 done... check grounds... with that type of electrical you should be solid on a aq 3500.1 unless your running a dumb low ohm load.. big3 done ground dont move at all nice clean straight bodyframe as for my other batts there connected to the negative batt to the front, and not that low im at a 1ohm load Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted July 18, 2011 Author Report Share Posted July 18, 2011 well i currently have 2d3100s in my trunk and one 3400 under the hood and 1mechman 270 in my car and when with the car off its 12.6-12.8 all depends if i charge my batterys or not on my xspowercharger1215 and when the car is on around 13.6 very rarley see it go past 14volts even when im driving and dont play my system for 10-15mins any help? i would like to add more power but i fear huge voltage drop i run a aq3500d1 and plan on running 2 sundown3500s really soon also car is a 05ford mustang Check into the XS Power VCM... It has adjustable voltage on it, and you can add additional alts later on if need be too... The xs vcm as boiler said...you can set your alt to charge @ whatever you want. will it work for my car tho? you think it could be the pcm in my car? or w.e its called the computer taking away my voltage? Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted July 18, 2011 Author Report Share Posted July 18, 2011 I'm having the same problem, but with stock alt and XS D3400 under hood w/ big 3. My truck stays at 13.6-13.7 when driving, with no amps connected. Is it just something that some vehicles have that cause it to stay at that level? thats is somthing i wouldnt know because we have different vehicles but it could well be Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
tonedeaf Posted July 18, 2011 Report Share Posted July 18, 2011 There's some trucks out there that control the voltage with the ecu iirc and limit it down decently low. Can't remember what vehicles do that, and I'm not sure how to bypass it either. I would doubt the mustang does it though...orionstang would be a good person to ask. Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted July 18, 2011 Report Share Posted July 18, 2011 The 05+ Mustang should be PCM controlled, that will eliminate the adjustment of your voltage until we develop a device to work with your PCM to provide voltage adjustment. It's more complicated than our other voltage adjusters by far as the computer is using pulse-width modulation to control the voltage output and is looking for a specific voltage based on it's programming to determine the load of the alternator on the engine. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted July 18, 2011 Author Report Share Posted July 18, 2011 The 05+ Mustang should be PCM controlled, that will eliminate the adjustment of your voltage until we develop a device to work with your PCM to provide voltage adjustment. It's more complicated than our other voltage adjusters by far as the computer is using pulse-width modulation to control the voltage output and is looking for a specific voltage based on it's programming to determine the load of the alternator on the engine. so does that mean im stuck on what i have then Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
