Too bad Autruche, I guess I take that as a compliment? Although, you wont get that clean "factory" look without cutting them.. But i think it's turning out fine :)
Oh, no I mean that my front door panels are literally cut into 6 pieces from changing my plans for my door panels so much. I'm on my 5th door panel rebuild now. Basically, I'm just making something to hold me over for now, until I buy new front door panels.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Nice job on bolting. Did you cover those with fiberglass? If so what reason was that for? I only ask cause if you ever have to remove them for any reason, I'd think that would cause some problems. Coming along nicely though. Nice job!
To stiffen up the back of the box. It might become a problem, but I'll deal with it then.
Nothing have really happened the last days, I've been away helping my mother with some building, and tomorrow I'm going away again, to another place though. Staying over the wheekend :shrug:
On the bright side, I got my 15m (50ft?) of 1/0 gauge today :) And parts for my clutch is on its way, so I can get the car on the road again :woot: Also I wonder when my LEDs will arrive ?
Today i got my main clutch sylinder, brake and clutch bleeding kit, piranha LEDs and nice weather to work in :D I tested the LEDs and they have a wide and even spead to them, just how we(?) like it.
Now out to do work!
The project look like its coming out good. Well good luck and you should post up more pics once its done.
2004 Melky Toyota Scion xB
Kenwood Touchscreen Headunit
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
6 Tweeters Audiopipe
1 Rockford Fosgate T2500.1 bd
1 Lanzar 3000
1 Audiopipe 1500
2 Optimum YellowTop Batteries
The Big Three
19" rims
and more..
http://www.stevemeadedesigns.com/board/topic/119197-build-log-scion-xb-4-15-kicker/
What you see in these pictures is the molested clutch friction plate and the LEDs for the window.
If you look close at the clutch pictures you can see that on one side the friction material is still intact, though wery worn, and on the other side it's all gone :trippy: It got so worn that it just shred itself to fibres that poked out of every hole in the bellhousing..
  • 3 weeks later...
Seems like a long time since last update, but I have started on the doors again. Leftside doorpanel is on the door pretty much, with wires ran through the stock "rubber thingy".
Some dampenig have been done in the hatch area, but more is to be done. Backdoors are also screaming for some deadening.
I'm currently waiting for some parts to replace a leaky exhaust system. Might have to replace the head gasket aswell... Oh well, as long as i dont screw up the valve timing i should be good :ehh:
Also, this Saturday the local car audio guys are arranging a small db-contest and I'm planning on checking it out. It wil be my first time ever so it should be cool to see what kind of level theese local cars are at, and what kind of rules they are following.
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 2073 Guests (See full list)
