Before i seal up my box, i'm doing subs up port back for 2 12's. the port is in the center and there is a T divider in the back. Any suggestions on what corners to put 45's in?
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
For a daily box, I wouldn't worry too much about them. Yes they can add strength to the corners, but if ya build a solid box it won't matter. 45's also don't always add spl ;)
All of them if possible. At least the upper right/left corners and bottom right/left corners if looking at the box through the baffle
Edit: ^I guess I stand corrected. They aren't necessary lol. BUT if you are going to add them then you can go ahead and listen to me :shrug:
Edited by DRauck
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
Bottom right/lleft corner you are correct, upper right/left corner i´m not sure about that one, it might work
, but all of them NO, for dialy you might not be able to hear a difference, but on real life, it´s gonna hurt your score.
45´s aren´t that necessary if you ask me, specially for a daily application, i wouldn´t take to much attention about that...
so if i wanted to, looking at the front through the port it would be the front left/right corners running vertical? I forgot to mention the port outlet has a 5 inch radius bend if this makes a difference.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
if it´s subs up/port back and you are looking through the port, i would use a single horizontal corner (from right to left)at the bottom of the box, that´s the pressure point of that box
along the front panel right because the port is in the back. I have the bend in the front and that may be a little tricky.
also i want to post a pic of the "T" divider. I used pvc roundover instead of 45 mdf. Never posted pics. How do I do that?
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
try uploading pictures since my english isn´t that good lol, upload them on imageshack.us , get the direct link and post it on the image option at the tool bar you have on the top when you are writing a post...
Here is a super rough draft of the box. Between which points do you suggest the 45?
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
