betwen I-K, J-L, A-E and H-D, once again its not necessary and maybe overkill, but if you want to do it go ahead, it wont hurt anything
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
Oops forgot to erasw the first http...here it is.
Here is a super rough draft of the box. Between which points do you suggest the 45?
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
i just told you in the post above this one.... but once again, in this build its just because you want them there, theres likely no real benefit
1969 Chevy Chevelle
MY BUILD
I can't read the handwriting too well, but if you are stuck on putting 45s, do it in the pressure poInts, which I believe is A-i (A going diagonally) and D-J (D going diagonally)
Here is the "T" divider using 3" pvc. So it only extends down the port 1 1/2 inches and the port width at the top is 2 1/2 inches. Should I make an extension from that down the port farther or will this be ok?
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
If I remember correctly Fecoupe said the flat topped separator is what worked best for his box. Like /T\ but without the leg in the T if you get what I'm saying. Yours may differ though.
Like if you took what you had, spread it out a bit, and put a piece of mdf in the middle. In the same thread, someone else said they lost when they did the same thing, and a separator like what you have worked better. The general consensus was a separator made a difference though.
Moral of the story? Try it and see what works best. Between the three options (none, flat topped, peaked), I think it was like a two or three db difference.
EDIT:I was wrong on a few of the specifics. Read this thread.
http://www.stevemeadedesigns.com/board/topic/114812-middle-port-triangle-poll/
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Good thread...thanks. I think I will flatten it back out and then put a piece of wood at the end to run it down the port a little farther. I could just redo with the wood inbetween the two Pvc pieces but I'll probably have to 45 the bend because I don't want to choke it too much. Also think I'll do pvc on the two pressure points just because.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
