I'll lookin to upgrade in the future to 2000W so if I were to have say a crescendo bc2000 running two 1000W subs, what electrical upgrades would be necessary?
Right now I have everything stock, no big 3, 1F cap.
I was thinking 1/0 wire everywhere, big 3, and one extra battery (don't know which one).
Would this be good?
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
First, ditch that useless cap, then put 1 decent quality batt in back, followed with a BIGIII install (please fuse both ends of pos cable!!) some quality grounds, and that should really be it. Later on, upgrade to a HO alt, nd maybe 2 runs of POS, and NEG to back batt....
I love my staffie :good:
So anti FACEBOOK it isn't even funny
Do the Big 3, Ditch the cap, get urself a good battery for the back, hell if you want get one for the front too. examples XS, Stinger, Kinetik to name a few. Run a 0/1 ga line from front batt to back batt, 2 if you plan on going bigger in the future.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
i would get rid of the cap, upgrade the fornt battery to an AGM and add a second AGM battery in the back. 1/0 big three and 1/0 front to back, maybe a positive and negative from front ot back depending on your budget.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Yeah the cap will be gone. It was a fix in a 92 lumina and figured i'd use it as long as I had it. Got an 03 bravada now.
probably won't go bigger than that. As years go by I have less and less free time so I'm lookin for just what is necessary for this amount of power.
So 1/0 big 3 with one run to battery in back and I can keep the stock bat and alt?
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
I dont mean to jack thread, but have a similar question
thinking about running 2000w
2x 1000w amp not sure on brand and 8x 12s Street Duty SDC2.0 500w 250rms
its an 84 chevy G30 V8 350 5.7L full size van with absolutely no power anything, stock AcDelco casette radio, no AC "heater coil only", not even interior lights atm.
i was going to do BIG3, get a 140amp Powermaster alternator and an AGM under the hood, and all 1/0 wire
would that be enough power for now? i dont really have the budget for an H/O alt yet, but could prolly get 1 in the next couple months. might be able to afford another battery in back
system setup would be for daily, car cruises, and a bit of idle while working in the garage and
the most i would have the system on for would be maybe 2-3 hours at a time if that long per day
(edit) wont even be wiring it all up for atleast another month, just needed to figure out what i would need MINIMUM for power.
Edited by Grelko
Optimus XL-400w amp 2x 10s IMPP 400w 2x something or other in dash 2x 35w radioshack 8" full-range AcDelco factory radio "frankenstein'd from my dead buick" Dodge seats 1984 Chevy G30 full size 1-ton van "Rust Monster" Progress - around 15% primer/patching
Sold the van in 2014, had it about 75% done, never did get the system in it. Bought a 2000 Chevy S10, still using the same amp/subs. Headunit is XO Vision X538. It's 52x4w, has a dvd player, auto flip out 7" touch screen plus alot more and is a single din.
Op, big 3, and the biggest xs or kinetik batt that you can fit under the hood. It's not good to mix regular batts with AGM batts. But I run a bc2000 and voltage never dropped below 13v with an XS D3400 under hood, big 3 in 1/0, and a stock 118 amp alt.
:rofl:
:wub: N8.
No homo...unless you want there to be. :orly3::ehh:
got my answer in another thread, ty
Edited by Grelko
Thanks everyone..sounds like LB has the setup I'm lookin for.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Edited by Tarball
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 3561 Guests (See full list)
