I'd go with the 1500bdcp above all the other amps mentioned here...
Using pass thru is fine. Gain matching is tricky, you have to measure the output voltage of both amps and make sure they are the same AND make sure neither amp is clipping.
so i can use a DMM and a 33htz test tone to see what the voltages are at on the speaker terminals?
and the clipping is with an o-scope correct?
Basically, but check the voltage at the amp, no speakers hooked up. Also, once you set the voltages right, if you use an o-scope the check for clipping and you have to adjust the gains, gotta go back and match them again.
AQ has some nice amps, so does sundown, dc audio...lots of nice amps that are cheaper than the RF amps. None of them have cp though! But you won't be disappointed in an of what I listed.
looked into a DC 2k...shipped to me for 595....dont rlly wanna spend tht much.
i saw a used t1500 on Craigslist for 300. rlly thinkin about it. but idk. id like a warranty.
i was only looking to spend 300-ish.
whats your word on a hifonics BRZ1700.1 and BRZ2100.1
would the 1700 actually put out about that much true RMS
or should i go for the 2100?
those are decently cheaper. what do u think about the quality tho
Hifonics would be a step or two lower than the sundown and rf the we mentioned, but they do pretty close to rated, I'd get the 2100 if I were you. But for that price you could also look into a crescendo bc2000. I think it's a step up from the hifonics and it's about 349 shipped
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
You won't find a good H/O alternator for under $200.
You don't need one either though. For 1500w the Big 3 and an upgraded battery under the hood will do just fine, and anyone who tells you differently is an idiot.
jus dunno if i should get it used or not.
and do u kno of any sites for HO alt's under $200?
somwhere around 200 amp
No! And if you see one you better tell my ass!!! Haha
so far...
X2 unless your alt is like a 20 amp lol
so far...
i have 2 of the big 3 down in 0 gauge...i ran out and couldnt do the engine to battery (-)
could i just use a optima redtop?
my alternator is only charging at 13.4 on my Cap right now...so im positive its takin a shit on me. ive been bangin on it for almost a yr now.
Get the cp version if you go RF!
those subs will hate that amp haha, 1800- 2000+ rms at 1 ohm! How I love underrated amps! :woot:
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
<a href="http://tinypic.com?ref=2r3c8xw" target="_blank"><img src="http://i52.tinypic.com/2r3c8xw.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
not an L shaped port...just a slot. aproxx 17 inches deep...15 inches tall x 3 inches wide
Then it's probably a gain issue because you're using two amps. One gain may be slightly higher than the other
i just dont get why one amp picks up the lows better...im using the older gray zx750...and a new 2010 zx750(black one)
could there be a diff between them in power and shit?
Yes. This is the problem. You set your gains wrong and the amps are different.
FML. i jus wanna sell em both. and get a RF t-1500.
run it at 1 ohm.
If you did this, you would not be disappointed
i had a RF p.1000.1 but then i thought 2 zx750's would be louder...but i fucked myself over now...i just sold my p.1000.1 to my buddy.
i had em pushin around 1200rms from tht RF amp. but i was lookin for a wee bit more.
any suggestions on a good cheaper amp than a t-1500? but still gets me around a true 1500RMS
crescendo 2k, DC 2k?
Get more 0awg wire, finish up the Big 3. I haven't had experience with Optima, I normally suggest XS Power batteries to anyone looking to upgrade.
Also, remove that capacitor, it isn't helping your situation at all, and can possibly hinder it.
Edited by Supercharged DCs
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
