DerekLeonard Posted July 24, 2011 Report Share Posted July 24, 2011 im wanting to run 6 audio que sdc2.5 10s i want to know how to wire them all and what ohm level that it would be trying to shop for an amp thanks i wasn't asking you but thanks for being a nosy fool I really think you have a learning disability. Link to comment Share on other sites More sharing options...
6berry Posted July 24, 2011 Report Share Posted July 24, 2011 what ohms are the subs and how many amps are you planning on? 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth Link to comment Share on other sites More sharing options...
DerekLeonard Posted July 24, 2011 Author Report Share Posted July 24, 2011 the subs are dual 4s and i would really like to only run 1 or maby 2 amps i wasn't asking you but thanks for being a nosy fool I really think you have a learning disability. Link to comment Share on other sites More sharing options...
Supercharged DCs Posted July 24, 2011 Report Share Posted July 24, 2011 3 D4 wires to 2.67ohm nominal, so if you decide to go with two amplifiers keep that in mind. Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
AA98hoe Posted July 24, 2011 Report Share Posted July 24, 2011 6 d4 subs wired series parallell would put you at 1.3 ohms should work nicely with most quality amps like a aq3500.1 TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
DerekLeonard Posted July 24, 2011 Author Report Share Posted July 24, 2011 cool thanks guys i wasn't asking you but thanks for being a nosy fool I really think you have a learning disability. Link to comment Share on other sites More sharing options...
