At the same time, you realize its 100+ degrees here, not sure what it is where you're from, but I would imagine that might also effect it.
totally true, in the summer my alt charges almost a whole volt lower when hot as opposed to when in the winter.
summer here is 75 80 tops. winter is 30s almost never in the never in the negative degrees (maybe on a super cold winter nite) last september alt and batts were reading 14.7 u think after running in cold weather for 4-5 months then when the weather warmed up it changed my charging voltage???
wynndiesel are you the same as wynn just different name?
my last name is Wynn. wynndiesel is a nickname my friends came up with making fun of me! it kinda Stuck for a few years! sounds like vin diesel ya haha funny!
I dont know if you did this or not, this is only something to consider, but when you first checked it was your air conditioner NOT on in your car and it is now? Because that load usually lowers the voltage. Just something to think about if you have an added load on the vehicle now when it's running.
Cactus Sounds USA Team Captain
Multiple World Record Holders
voltage stays the same with ac on and off. maybe changes by .1v
I had this happen with my 04 envoy. The alt is regulated internally by itself so its not like the newer vehicles where the ecu controls my voltage output on the alt. The problem mine had is that the ground from my battery to the engine and frame was getting rusty. Everytime i cleaned it up, my voltage would come back up to 14.9v warm but when it got a little bit of rust, it would start to drop back down at 13v. I also noticed a random "dancing" affect of my volt meter in my dash when i first started my truck up. The voltage would go up to 14.4v but drop to 13, go up, back down, and then stay steady. As soon as i fixed the ground it worked fine. I would just double check your positive and ground wires in your engine to make sure they have no corrosion or rust on them and go from there.
Mine was extremely sensitive to rust and would screw up my charging system a ton with it.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
  • Who's Online   0 Members, 0 Anonymous, 1597 Guests (See full list)
