Wall enclosure trunk behind rear seat . Advice....
guimond47
alright boys. i have 3 alpine type R's and a grand prix.. i hate the set up i have now as its space taken and feel like i can get more outta it. i want to make a wall enclosure sub box . i was told that its louder if its sealed off correctly from the trunk. something like this http://www.caraudio.com/forums/enclosure-design-construction-help/352731-trunk-wall.html
now my origional setup is 3 12's firing up words with port facing back of trunk. would it be better if i had the 3 subs firing up and port facing me? . i have a hole in my back seat that comes down. the hole is about 1 ft wide x 2.5 ft high. soo in conclusion the port facing me ( i'd be able to see it looking back trough the hole) would it be louder like that. or wall enclosure better? . my box is tunned for 30 hz . soo it slams nice and low. let me know what you think. my second option would be to dyna mat or second skin the whole trunk to keep the bass in there . I would like ideas from youguys so please post . thanks.
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
its different for every car and every setup but i believe subs and port forward sealed off would be the loudest. another thing you could consider is doing a 4th order with the port coming through that hole in the back seat. im doing something similar in my car. my build thread is in my signature
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
<a  href=th_IMG_0616.jpg' alt='th_IMG_0616.jpg'>
thing is with that is i have 3 12" subs , i wouldnt be able to face them foward unless i get rid of those and buy 2 alpine type X's. but i also thought of if i turn my box around and make the port facing me would it make a difference...... being with leaving the subs firing up wards due to lack of space..
i forget how to post pictures but this is my setup . (with the port facing the back of the trunk.
http://s1142.photobucket.com/albums/n614/guimond47/?action=view&current=IMG_0616.jpg
So you want to use 3? Whats the impedance of the subs, and what amp do you have them on? I think it would perform a lot better if you only use two, face them forward, and seal off from the trunk. Check out my box build and design (sig) if you want. All I need to do is seal off and it's just a matter of doing it but I never did. When I open my trunk it's louder which means there's cancellation and sealing off should keep all the bass and pressure in the cab.
Or yes, if you like how it does now deaden the trunk and it should make a difference.
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
final ohm is 1.3 ohm and im using the hifonics brutus brz2400.1d bad boy. and yea im thinking the port facing the opening of the seat should make a diff so the air goes into the cab.
if its in the trunk its not a wall.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 861 Guests (See full list)
