*Type of wood used for box*
Well, the reason they're both great for enclosures is that they DON'T resonate (a lot) in the passband of normal subwoofer output. I like birch because it's light but it's more delicate to work with (splinters) than MDF. MDF on the other hand machines more consistently so sawing and using a router on edges is easier IMO.
Also, MDF does not absorb water very easily. I think the other poster was thinking of particle board, which should not be used for sub enclosures, because particleboard DOES absorb water easlily and that it splits when drilled or screwed on the spine.
at Lowe Depot, birch is $10-15 more than MDF, but I found lumber yards that specialize in hardwoods seem to carry birch and it's about $35 a sheet. It's worth a glance in the Yellow Pages.
Edited by srp365
2007 Pacifica
With sound you actully want the panels to be heavier. Its a way to dampen the box. People are saying ply is stiffer. Well it is but it isnt if that makes sence.. Long storie short, birtch resonates more then mdf does. Mdf is better imo
Fiberglass and resin the inside then.
ive wondered this also, what difference does the resin make ? i am wanting to do this, but their is no point for me to right now, becuase i dont have the basic concept of what it will do lol
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
Thats not going to change the dampening of it all that much. Will make it stronger and more ridged yes. But what mdf does it adds mass to the panel itself which is what you want.
People claim the resin makes it stronger. I use resin in my screwless design that only use liquid nails. It adds strength and rigidity supposedly.
Its cheap, and some people claim it can gain a .5-1 db gain in SPL designs.
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
ok.. now i kinda git it lol, sounds like a challenge for some to take over =P " resined box vs. non resined "
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
It has been done. Even Steve himself recently said he uses it because it gives the box more strength. Not because it massively increases the DBEEEZ :clapping::drink40:
Resin alone does not add much strength to an enclosure. Resin+glass mat, however, does :)
:yahoo: COOL! less work for me lol. only problem is the mess fiberglass makes =(
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
You are only going to use the resin. If you wear gloves and take your time, and mix things right its not bad at all.
Never thought about saving weight with a less dense wood. If at some point I do a rebuild, I think I will try Birch or Oak to try to save some gas/acceleration.
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
  • Who's Online   1 Member, 0 Anonymous, 1622 Guests (See full list)
