Well Id just say i wouldnt do it. You'd have to look into the contruction of your car.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks for the insight. I think I prob would have got myself in a big predicament. But I will check into it more because the idea just sounds awesome.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
what size subs are you thinking about mounting there? if you are trying to put your subs in the same spot your old deck was, they better be some 8s or MAYBE 10s because most decks arent that deep. if you are just wanting to cut it and still leave the subs on a box in the trunk, i dont see that much gain to be had versus just porting through the deck. i jsut did this to my 69 chevelle over the weekend, port firing up through the rear deck.
tapeing the pattern underneath the deck...
piece that was removed...
view from above, still have a beauty ring that has to be installed to cover the edges
Edited by zx10intn
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
What i was going to do was use my rear deck as a baffle for just my subs. Useing 2 layers of 3/4 mdf on the underside and 1/2 on top to countersink the hell out of them and add strength then port threw my arm rest. Oh i was going to do this with 2 sa-10s.
I was talking about kind of the same thing except porting inbetween the subs. Its with 2 12"s. I know itll be tight but theres enough room but it would inquire some cutting
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
I was thinking of building a box in the trunk and having the the subs/port where the deck is. It might not be a big gain but it would be different.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
do a 4th order.
W/hdc3s? Im not too knowledgeable on 4th orders. You have an idea?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
do a 4th order.
HDC's would love the 4th order...
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
do a 4th order.
What are the perks on a 4th order?
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
