The CP series of amps also make rated at 2 ohms. You just don't get their full effectiveness at 2 ohm.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
wouldnt the rca voltage be too high?
You would need to adjust the amp accordingly. But that should show you if it's the HU or not.
And yes, Alpine is 2ohm peak.
And yeah most amps will work at 2 ohm, just not there peak
Edited by Purplehaze
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
adjust the amp accordingly for the ipod test? readjusting the gain u mean?
and what you mean not get the full potential at 2 ohms from the RF CP?
Edited by VIP3R
2 Sundown Audio SA-10s
Box built by Speed of Sound
Kicker 1500.1
Infinity Ref 475a
Rockford Fosgate T1682c 6x8s
Pioneer Premier DEH-510UB
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
I'll see if I can't find the thread where this was discussed. Others will be able to explain it better than I can. Long story short, you don't get the full effect of constant power when run at 2 ohms.
http://www.stevemeadedesigns.com/board/topic/88684-what-is-cp/
Edited by BJD3
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
Turn the ipod down. You wont have to adjust the gain as long as you dont crank the ipod up to run the amp hard.
Hammerdown... 1%
gotcha. well its like any amp imo..youll never get TRUE full rated power. as long as it pushes the rms at the right ohm rating I am fine right? should i not bother with this amp or what?
on a side note, why 4 gauge wire? when most other amps I seen for this rms need 0 gauge?
alright sounds like a plan.
Edited by VIP3R
Kicker 1500.1
Infinity Ref 475a
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
still havent tested the headunit thing yet, but it was weird...cause as soon as i gave my headunit more volume.....and brought it back down..the bass at the same volume level where i started was higher...
so does that equate to the headunit or something faulty in the amp?
but then again...i turned the sub output on and off as well...so who knows =/
Edited by VIP3R
Kicker 1500.1
Infinity Ref 475a
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
How did you ground your amps?
straight to the frame. and at the same spot. grinded down nice. then siliconed over to protect.
the more and more im playing with it it seems like the amp but im still not sure.
found out my headunit doesnt do jack for preout voltage until almost to the end of the volume knob from testing.
Edited by VIP3R
Kicker 1500.1
Infinity Ref 475a
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
That's normal.
