kirill007 Posted August 11, 2011 Report Posted August 11, 2011 The price for the batts, alternator and box build+ big3 and the price to build it all into the car is good. (1500 isn't that much since alternator is 400+ 2 batts is what 500? and wire for big 3 + box build material equals to about 1100 and 400 for labor is not alot) MatthewBigbossWilliams, The last list you made seems to be good, but why not tsunami wiring and second skin as deadener? Do you really need the equalizer? it can do more harm then good if you aren't experienced, you can make it sound like shit or even worse, burn speakers/woofers up. Just dump the EQ, more money for wiring kit, and do you really need 2 BL's? Maybe 2 SSD's on that power should be better and cheaper. THen you have some money left for decent wiring and or something else. Thinking is the root of all problems... You ALWAYS get what you pay for.
MatthewBigBossWilliams Posted August 11, 2011 Author Report Posted August 11, 2011 second skin is slightly cheaper and a better product than dynamat. check them out. what brand alt and what is its output? there are a lot of cheap alt options that will actually be WORSE than your stock alt. we can make sure you dont get one of those. http://www.mechmanhighoutputalternators.com/shop/products/220a-Focus-Zetec-High-Output-Alternator.html Thats the brand and description
MatthewBigBossWilliams Posted August 11, 2011 Author Report Posted August 11, 2011 No need for a high output alternator. Pioneer DEH-3300BT - $340 Clarion EQ- $70 2 X Alpine Type R 12s $270 Second Skin Damplifier 20 sq feet $70 Pioneer 5 1/4" component speakers (FRONT) - $80 Pioneer 5 1/4 coax (REAR) - $30 2 x speaker adapter plates $20 Hifonics 5 Channel Amp (240 RMS @ 4 ohms on highs, 1000 RMS @ 1 ohm on substage) - $350 Cadence 1/0 wiring kit - $60 2 x cadence 17" RCAs - $26 50 foot cadence speaker wire $14 Torres box tuning Calculator - Create a box 4-6 cubic feet that is atleast 30" wide. Put a port in between the subs, port area should be 15 sq inches per cube, tuned to 36-38 hertz for daily listening. Take the cut list that torre's box calculator provided you with on the upper right hand side of the program down to home depot. Have them cut you out a box, ask them for a 1/8" tolerance, in hopes that it'll be 1/4" tolerance when they are done with it. Couple things you should know... 5x7s are nothing great. A nice 5.25" or 6.5" component set with strategically placed tweeters on the front stage will definitely out perform most if not all 5 x 7 coax style speakers out there. Coaxial speakers in the rear stage will work just fine. Rear stage is a filler, nothing more. Power acoustic double dins are no good. I'd take a pioneer deh-4100ub over any power acoustic double din out there. I've owned a PA double din. Picture quality was grainy, eq was worthless, interface was annoying, and ipod/ usb adaptability sucked. Do yourself a favor, spend the extra $100 on the pioneer 3300. You'll be very happy you did. Alpine type Rs... Great sub for the money. Can't go wrong if you're on a budget. As far as 5 channels go, I've never been a huge fan of them... But this new hifonics one looks pretty promising and the reviews on it seem to be solid. I think it'll put out what you're looking for as far as power goes. The list you had going was a mess. If you want a good looking system, keep it simple. If you're going to buy brand new amps, don't mix brands. I made you a $1300 list of equipment that would be a solid system if installed correctly. I'd be willing to bet that it would outperform the system that you were thinking of in price, sound quality, and cleanliness. My $.02 EDIT: A pair of Fi BL subs probably wouldn't be as loud as a pair of SSDs off the power you're giving them. 1500 RMS is what the BLs like. You'd be maybe 750 rms each with the amp you chose. You don't need 8 gauge wiring going to your subs 600-1000 Watt RMS subs. Check out the tinsel leads on your subs. That should give you an idea of what size wire you should run. You'd be fine with some 14 gauge cadence wire going to your subs. Ditch the battery isolator. There's no reason. It will do more harm than good, possibly making the input voltage to the amp worse. All the equipment that I have, i already went through with other people. I posted a beginning list prior and heard from several people "get rid of the Power Acoustik stuff." They said the Brutus amp will be fine.
MatthewBigBossWilliams Posted August 11, 2011 Author Report Posted August 11, 2011 ^^^looks like he meant a Ford performance part I did mean for a 2001 Ford Focus with Zetec
MatthewBigBossWilliams Posted August 11, 2011 Author Report Posted August 11, 2011 The price for the batts, alternator and box build+ big3 and the price to build it all into the car is good. (1500 isn't that much since alternator is 400+ 2 batts is what 500? and wire for big 3 + box build material equals to about 1100 and 400 for labor is not alot) MatthewBigbossWilliams, The last list you made seems to be good, but why not tsunami wiring and second skin as deadener? Do you really need the equalizer? it can do more harm then good if you aren't experienced, you can make it sound like shit or even worse, burn speakers/woofers up. Just dump the EQ, more money for wiring kit, and do you really need 2 BL's? Maybe 2 SSD's on that power should be better and cheaper. THen you have some money left for decent wiring and or something else. I redid this and I can get the budget portion of this fine. I can get wiring, that's no issue for this at all. I also don't need FI's. I want them
CJ18 Posted August 11, 2011 Report Posted August 11, 2011 www.singeralternators.com Check out Mike Singer for your alternator. He quoted me a GREAT price on a 350a alt.
skittlesRgood Posted August 11, 2011 Report Posted August 11, 2011 second skin is slightly cheaper and a better product than dynamat. check them out. what brand alt and what is its output? there are a lot of cheap alt options that will actually be WORSE than your stock alt. we can make sure you dont get one of those. http://www.mechmanhighoutputalternators.com/shop/products/220a-Focus-Zetec-High-Output-Alternator.html Thats the brand and description oh ok. good choice. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
MatthewBigBossWilliams Posted August 11, 2011 Author Report Posted August 11, 2011 second skin is slightly cheaper and a better product than dynamat. check them out. what brand alt and what is its output? there are a lot of cheap alt options that will actually be WORSE than your stock alt. we can make sure you dont get one of those. http://www.mechmanhighoutputalternators.com/shop/products/220a-Focus-Zetec-High-Output-Alternator.html Thats the brand and description oh ok. good choice. are you being for real? i cant tell sarcasm right now lol
skittlesRgood Posted August 11, 2011 Report Posted August 11, 2011 mechman is a good brand. im not fucking with you. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
727Designs Posted August 11, 2011 Report Posted August 11, 2011 second skin is slightly cheaper and a better product than dynamat. check them out. what brand alt and what is its output? there are a lot of cheap alt options that will actually be WORSE than your stock alt. we can make sure you dont get one of those. http://www.mechmanhighoutputalternators.com/shop/products/220a-Focus-Zetec-High-Output-Alternator.html Thats the brand and description oh ok. good choice. are you being for real? i cant tell sarcasm right now lol Mechman is a good choice. Also look into DC Power, and as mentioned earlier Singer Alternators. Mike does great work. -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
