gowerryan Posted August 13, 2011 Report Share Posted August 13, 2011 i have a single cab 93 silverado and i was wanting to do a build with the little sundowns.........at first the plan was too just use 2 of them but i was wondering if i could do a ported wedge box for 4 of them behind my seat? i am kinda tall(around 6'3")so rooms kind of an issue but not a whole lot any one think i could fit them?........and to go with that could i bolt them with lag bolt to the body 2 on the bottom and 4 on the back.......one more question is do u think i could use a rf t1500.1bd to run them all? 95 toyota corolla 1.8 dohc 5 speed system in planing stages right now Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted August 13, 2011 Report Share Posted August 13, 2011 amp is fine, but i know where your coming from being 6'4" myself. Unless you can fit about 3.6cubes after displacements behind your seat i would go with 2. And hell, if you know what your doing, you can use all 1500rms on 2 sa8s, just be smart about it. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
EBW Posted August 13, 2011 Report Share Posted August 13, 2011 The sa8s are tough as nails just remeber when the ft^3 goes up... the power handling goes down but you should be able to do pretty good with 2 8s don't want to make it a pain to drive cause a box is more important. Even do 2 10, slot ports can do funky stuff in a wedge id go with aeros. Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
gowerryan Posted August 13, 2011 Author Report Share Posted August 13, 2011 The sa8s are tough as nails just remeber when the ft^3 goes up... the power handling goes down but you should be able to do pretty good with 2 8s don't want to make it a pain to drive cause a box is more important. Even do 2 10, slot ports can do funky stuff in a wedge id go with aeros. what do u guys think 2 will run in the numbers? this is a first big build and i want it too rlly slam 95 toyota corolla 1.8 dohc 5 speed system in planing stages right now Link to comment Share on other sites More sharing options...
EBW Posted August 13, 2011 Report Share Posted August 13, 2011 Well it depends all on ft^3's tuning port/sub firing direction, on 1500 rms you shouldn't have a problem getting lower 140's but their rated at 400 rms each (which is under rated btw) if you give them clean power they will hit like ike turner Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
EBW Posted August 13, 2011 Report Share Posted August 13, 2011 First thing I would to is make sure you seat is where you like it then measure LxWxH include top and bottom is your doing wedge and post back when you get the dims Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
bdog Posted August 13, 2011 Report Share Posted August 13, 2011 jacob says the sa-8 like as small as a .3 per sa-8 when lots of sa-8s are using in a common enclosure. So find how much volume u have then decide what way to go . Sundown is also launching the lower mounting depth line where the 10" woofer is only 4.5 inches deep REP Link to comment Share on other sites More sharing options...
gowerryan Posted August 13, 2011 Author Report Share Posted August 13, 2011 thxs guys i have to rebuild then engine first but i want to have everything planned out first 95 toyota corolla 1.8 dohc 5 speed system in planing stages right now Link to comment Share on other sites More sharing options...
