T line for,two twelves!!!
brent379
I understand that trust me and i do appreciate ur help alot!!! This is something i really wanna try... Just dont need to start it off feeling like a dumbass lol
http://i712.photobucket.com/albums/ww130/DHFHades/T-Linebox1.jpg
theres the one I built, box was 32 inches wide, not counting the sides. subs were mounted inverted on top, looked cool as shit...got loud, sounded good...what more can you ask. btw, I did not design that box, I got it from the old t-line tutorial :)
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
At the risk of sounding like a dumb ass, but what are the caracteristics and advantages of a t line? Any good for hometheatre/music combo setups? Thanks
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
they are made particularly for home theater, they have just been modified to work in car audio also, but work better in home theater to my knowledge, most reading you find online about t-lines are for home audio use
sweet I might have to look into it.
Build Log>>>
New Build
You are really making this harder then it has to be. Kynto is right by using the SD. You can't measure from surround to surround and call it done as its a CONE, not a Flat CIRCLE.
Sound travels at 1130 feet per second. Divide that by desired frequency then divide by 4 to get the length you want. Most people use the fs of the sub to get the frequency they want.
simple, done. It you still can't figure it out stop asking us and go back to 5th grade math class.
Actually you measure from center of surround on one side to center of surround on the other side because the effective area is a flat circle. The depth of a speaker does nothing. The width of the surround moves on a linear gradient (near the cone it moves almost as much as the cone, near the basket it moves almost none) so measuring from the center of the surround on each side gives you the closest measurement for effective piston area.
Hammerdown... 1%
couple of other notes. you can "tune" above the fs of the sub but never below
you can have less port area than the sd but never more
play under "tuning" at your own risk tlines have no back pressure and will allow a sub to unload very quickly
make the airflow in the box as smooth as possible
and do not have any air leaks. it ruins the enclosure. majorly
You can tune below if you want. Most HT applications do. Air leaks are easy to deal with given the lack of backpressure.
Hammerdown... 1%
even more than SD considering SD is the factory (well whoever measures the t/s parameters) measurement of the effective cone area?
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
