Heard this from a guy the other day. He said that 1 bdCP is equivalent to 2 bd's. Going by the numbers, no it doesn't, but I wasn't going to sit there and argue with him about it cause usually he knows his shit. Just wondering what you guys think about it. I know the CPs are a lot better, but double a bd?
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
I'd take 6kw of power over 3kw of constant power. Chances are after rise you'll still get a good bit more power out of the two 2500bds versus the 2500bdcp... IMO :)
i think he means because of the 2 ohms power ratings. the cPs are birthsheeted around 3100-3300 rms at 1 and 2 ohms. The regular 2500bd is 1800rms at 2 ohms (rated, probably does like 2000 on birthsheet) and 2500 (~3100) at 1 ohm. So a cP being double, no, but much better, yes.
LOL @ people actually paying attention to birth sheets.
How does a 2,500rms amp equal double a 2,500rms amp? If this guy "usually knows his stuff" I think both parties need to do some more research, because they're both still 2,500 rated watts.
And when swapping out to the BDCP, it may have felt louder because the amp is able to give better output at the same amount of impedance rise.
A little more power, but definitely not double.
2004 Melky Toyota Scion xB
Kenwood Touchscreen Headunit
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
6 Tweeters Audiopipe
1 Rockford Fosgate T2500.1 bd
1 Lanzar 3000
1 Audiopipe 1500
2 Optimum YellowTop Batteries
The Big Three
19" rims
and more..
http://www.stevemeadedesigns.com/board/topic/119197-build-log-scion-xb-4-15-kicker/
