2volt / 4volts
Are you running a processor? What amp brand/model is it feeding?
Edited by EBW
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
Id like to know if I go from a 4 volt h/u to 2 volt would i be losing lots of power.
From what I'm given to understand, all a higher preout voltage will do for you is lower the noise floor since the amplifier doesn't have to be as sensitive. Higher voltage head units give a stronger signal out.
As far as losing power, no. That's why you have a gain knob. So you can set the amplifier to match the deck.
EDIT:That said, preout voltage isn't the only metric you should judge a deck by. That would be like saying "I'll buy this subwoofer because the magnet is bigger."
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
lower preout voltage will require you to turn the gain up some more to compensate for the lost 2v. as for losing power, you shouldnt lose any at all.
/thread
2007 Pacifica
You've closed the thread but I'm going to reopen it. lol
There is a school of thought that says putting a line driver behind a low power deck will rectify all the problems a low power head unit creates.
I would think that being that the line driver would still have to have that high noise floor then would boost that, you would still have all the noise you were trying to fight. If anything, running it through another device would give noise another chance to rear its ugly head. Correct?
Also, I've confused myself. I know what I want to say, but don't know the correct terminology. Would the noise floor be lowered or raised?
Edited by BJD3
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
i completely understand what you're saying. im going to throw out completely random numbers to try to put this into a real world example.
lets say you have a headunit with 2v preouts. .5v of that is pure noise. adding a voltage booster to boost the voltage to 4v, would essentially also double the noise, so the noise is now occupying 1v of those 4v.
unless im completely missing something (if i am, please correct me), like if some boosters have the ability to completely eliminate the noise, you're correct.
lets say you have a 1500 watt amp rms, and you have an input voltage of 2v thats is usable when its cranked, so not the amp has to bring that voltage up to 54.77 volts to have it output 1500 watts to a 2 ohm load, now that basically put it to having to increase the voltage ~27x the original input, now if you have a 4 volt preout into the same thing you will be only amplifying ~13.5x the original signal voltage, so in theory having a higher preout voltage would considerable lower the amount of noise an amp will let into the output signal, the higher the voltage going into an amp, as long as the amp supports it and its a clean signal that doesnt already have noise going into it, the better, you can think of an amp as just a voltage increase in all reality. Now if your running 7-9v's like I may be doing :P then your amp will increasing it about 7x, but that all depends on if my line driver in my 30 band eq will output a clean signal at those levels :D
Also another thing, if you put a line driver after a headunit, and there is already noise in the line, you would be amplifying any noise with it, same as the amp, the amp would amplify any noise in the line the same amount, so if you have 2v preouts, and there is noise, you would be amplifying that noise by 27x, that would be noticeable, now that all comes into your decks output clarity and any signal leakage from the RCA's, thats why higher preout voltage is wanted, because the amp will introduce less noise with the gain not having to be set so high, and the already small amount of noise in the signal will not be amplified as much, as every signal will have a very small amount of noise, sometimes not even hear-able, but still
Edited by dereileak
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
