SOME INPUT FOR MY BOX PLEASE
how should i strengthen my box?
7 members have voted
  1. 1. how should i strengthen my box?
    • Bracing
    • coating of resin
      0
    • both bracing and resin
trying to figure a better way to make my box stronger should i brace it or should i just coat the inside with resin i have seen lot of different types done but what do you think i should do???
box dimensions 36w x 19 1/2h x 14 d port opening 18t x 3 1/8w 31d for a tune of 35 hz. total box volume of 4.5 cubes for 2 12 inch RF T1's
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Can you post pictures of the box?
I gained some good output by bracing my box. I dont have any Resin in mine so I cant answer to that.
my box is gonna have threaded rod and fiberglass in it. resin doesnt add very much strength by itself (it adds some to mdf but almost none to birch) but with fiberglass it gets way stronger
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
i don't have the box built yet that's why I'm trying to figure this out ahead of time and no i dont have a 3d builder mabey someone who has one and knows how to use the program could use my dimensions and build a virtual box that would be epix!!
BIG 3
RF T400.4
all stinger wires
Well I glassed my box and now get zero flex,that's inside not out I did the braces and the mass of the space between using a medium matting and us compounds thin epoxy resin and 3:1 hardner with a little thickening agent here and there now its as stiff as can be but wow I ate up a lot of 40grit sandpaper tring to get it smooth be sure you don't let it set all the way cause it gets really really hard to sand down
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
i say build out birch it might cost 10 bucks more or so sheet but what you pay for resin. i just did 3 cub box no bracing and dont flex at all tuned 34 hrz. birch is way stronger and lighter. thats my input on that.
1996 dodge stratus
audiopipe 3k
2 15 american bass xds
10 door speakers threw out car
kenwood head unit.
spl scores from trunk: 147.7db on 2k
extreme out side window-129.2db
kaos 3 min average music-138.3db
  • Who's Online   0 Members, 0 Anonymous, 1261 Guests (See full list)
