How to calculate center port
Hey, I am thinking about doing a new box for 2 sundown nightshade 15s in the trunk of my maxima "subs/port firing forward sealed off from trunk". I've been messing with numbers trying to get around 100 sq inches of port, tune to 32 hz, and keep it around 6 to 6.5 cubes, but i am wanting a center slot "L" port and cant figure out how to calculate it when its in the center. To give you an idea of my trunk, i cant go past 40 inches wide, 17.5 tall, or 28 depth and i will be using mdf wood, double baffle, woofer displacement is .2 per woofer, and i plan to just glass the whole box on the inside and use the center port as the bracing. Any help would be appreciated
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
to calculate a center port you would measure down the center of the port from the front to 1/2 into the bend and then from that point to the end of the wood.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Just measure down the center, even if it turns 15x, keep measuring down the center and you can't mess it up
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
ok i kinda get it now, but here are the numbers i got, i just dont know the cutlist for the port(s) it says N/A
Team gg.
Think of it this way, if your port was 3" wide, each 90deg bend would have 3" of length in the bend, then add the length of the walls for total length
1969 Chevy Chevelle
MY BUILD
On other words, with a 7.5" port that's 33" long, you should have 25.5" of inside port wall length(with one 90deg bend) if using a side of the box and front or rear as the outer port wall
Edited by zx10intn
1969 Chevy Chevelle
MY BUILD
  • Who's Online   1 Member, 0 Anonymous, 1371 Guests (See full list)
