so, i ordered a termlab today and this will be the first time i have ever used one. my question is, how do you find the peak frequency you need to play at for the loudest burp? obviously since i will own it i can test all the time, but would something like playing a sweep at 1/3 volume and having it tell you the loudest frequency played work?
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
get a sealed box and run a sweep at about half volume...i find that sweeps are sometimes inaccurate, so after your sweep, play individual tones from say 3hz lower then your sweep read to 3 sweeps higher and see if its the same
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
thats to find peak freq of the vehicle. if he already has the box made just turn the volume 1/3 to 1/2 volume and play a sweep.
where it peaks at test the tones in that range on separate individual tracks and see which is loudest. on the loudest 3-5 of the freq tests, test them on full burps to see which one is key for your set up
NoFearX18 said:
trainman0978 said:
Make sure to write down each test score volume,frequency,db's..
Make sure your batterys get a good charge between each burp..wait 10 to 15 minutes between burps...this way you have a good score and accurate.
The sealed box thing is a waste of time. Play a sweep at a moderate volume (not too high to risk breaking anything, but not too low) to get a feel for what frequency range you are loud in. Once you get an idea, it's time to play frequencies in that range at full tilt. You must remember that your frequency can change with different setups, tuning, and also power. In my experience, more power often times raises the note.
1992 GMC Sonoma
2008 MECA S1 Champ, 2010 MECA S2 Champ
  • Who's Online   0 Members, 0 Anonymous, 3018 Guests (See full list)
