Best bass race songs
ay bay bay remix is what i use...ive had goood luck with it too
also drop it low lil wayne/easter or somethin
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Lil jon bme click. I used it 2 weeks ago I easily held 149.9 for 10 secs. I use to use airforces but never got a 149.9 but once out of 15 comps
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
no hands-waka flocka range of notes not a steady song at all
trap or die-young jeezy (decaf's) cannot use altered music in any dbdrag event
air forces- young jeezy good for those who peak at 43hz
money man-gorilla zoe again two frequencies which means its not very reliable as a bass race song as c-fizzy already explained
:drinks:
I used to use Thug Motivation 101 pause it right around 27 seconds closer to 28 and it is 30 seconds of constant 41hz bass
I used no hands at bass boxing and it did ok. I mostly use thug motivation after last show :)
you need to find out where your car peaks at. Then go from there.
"push that" is 43Hz constant and used by many. There's a show in Elgin, IL on the 11th that Jeremy is doing, should have bass race at that one. Also the 25th in Madison.
Push that nigga push that hoe by lil jon
Starts 24 seconds in and is over 3.5min constant at 43hz
It's what I used my whole rookie season
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
You not only want a constant note for 30 sec, but you want it to be the same note. If you play a song that changes from 38hz-53hz, your score will rise and drop accordingly. Air forces is my number one choice due to the consistent same note.
yup i know that so far i had that in my orginal post, thanks though :drinks:
:drinks:
added that to list thanks for adding the hz too kasey :drink40:
Lil jon bme click. I used it 2 weeks ago I easily held 149.9 for 10 secs. I use to use airforces but never got a 149.9 but once out of 15 comps added
Jeezy - Prime Minister
Jeezy - Welcome Back
added
pm sent on info on the elgin il show i wasnt aware there was two this season i went to the one month ago i believe and the 25th is midwest regionals correct?
It's what I used my whole rookie season i will try that man i will most likey be in the 39.99 class anyway and work my way up as my build begins to grow
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • 3 weeks later...
BUMP!
Can anyone help me find some songs that will be good for bass race around 50-53 hz?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
