depending on your box, rise will be around 2.5 ohms. Where is your sub installed and what is it facing?
Theres no way to tell where your rise will be...
unless you get a clamp meter and calculate it yourself.
Rise changes with every frequency
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Exactly.
Sounds like you're wired wrong tbh. With an XS D5100 on a T1000.1bd @ .7 ohms I drop to high to mid 12s. So no voltage drop with just a 3400...idk about that.
Completely stock electrical and an M1a and I have no voltage drop...
EDIT:To be fair, I have a bit of light dimming on things like bass kicks (I'm in need of the big 3), but on sustained notes, nothing.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
With a BC2000 wired at 1ohm, on stock 117A alt, single XS D3400, charging at 13.6v, my voltage actually increases with a load on it. Low volume, I rest at 13.6v constant, and at higher volumes it reaches up to 13.8v constant. It's odd, because when I previously tested out my BC2000 to make sure it worked properly, I dropped into high 12s. Now, I'm not dropping anything... Of course, my vehicle has always been odd.
OP, something doesn't seem right if you aren't happy with a 9515 on an AQ2200 as your first system. I was happy with a 3515 on a RF P200.2 lol
