Hey, i just got done with my build yesterday and have NO IDEA how to tune my amp. Im going up to a local audio place in a bout a week to get it tuned with an oscope because i dont have one but for now, i don;t know what to do.
I have 2 Amps - 1 AQ2200d and 1 AQ4x90
My box is tuned to 36 hz
What should i approxiamtly put these dials all at?
AQ2200D
Gain - .15v - 5v
Subsonic - 10hz-50hz
Bass Boost - 0-6db
LPF - 20-200hz
AQ4x90
Gain - .2v - 5v
Subsonic - 10hz - 360hz
Bass Boost - 0-12db
(2) No Names Dials - 45hz-450hz
If you guys need any other info dont hesitate to ask. Thanks
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
Always have bass boost off. I can't tell you where to set anything else.
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
no one can really tell you where to put your gains, it different for everyone. You need to know your preout voltage and match it with the amp gain. the better way of doing this is the oscope or a DD-1.
bass amp
bassboost - off
lpf-80hz
ssf- ~30hz
aq90x4
bassboost - off
hpf - 100hz usually.
AQ2200D
Gain - Leave alone until the shop sets it up for you
Subsonic - ~35hz
Bass Boost - 0
LPF - ~100hz
AQ4x90
Subsonic - ~100hz
Bass Boost - 0
*for channel 1/2, flip the switches to HPF (high pass filter) and 1x (not 10x) and then turn the knob to ~100hz (this effectively cuts off frequencies below 100hz so they dont distort, plus your subwoofer takes care of them anyway)*
*for channel 3/4, flip the switches to HPF/Full and 1x, subsonic to ~100hz, bassboost on 0, then turn the last knob to ~100hz.*
edit: the subsonic knob on channel 3/4 confuses me so i dont know whether to have it at 10 (make it effectively useless) or 100hz (match the HPF)
amp will let you set up a bandpass filter and uses the SSF to do that. He doesn't need it for his set up since he's not running active
30Hz would be fine for the SSF since you're tuned to 36Hz
this is extremely frowned upon here but as a temporary setup you could just use the clip light on the 2200d to set your gains. The light shows clipping early anyways so you should be safe... but at the same time I'm not responsible if you fuck up your sub.
2002 Camry XLE
35% tints all around
17'' Enkei FD-05 rims
Fi Q15 in 3.8cu ft box tuned to 32Hz
Pioneer DEH-P7200HD
AudioQue AQ1200d
4 Gauge Tsunami wiring/RCA's
mids/highs - OEM JBL system
AudioTechnix Deadner
Big 3 upgrade
My YouTube
  • Who's Online   0 Members, 0 Anonymous, 2007 Guests (See full list)
