Audiotistics Astro 64 tens Rockford Fosgate Build
  • 1 month later...
What's the status on This project
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
just one of those builds where the only thing i can say is holy shit... Cant wait for more!
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
OMG this is a crzy build. Great job so far.
91' CRX Si
HU - Alpine cda-7995
All stock interior
Amp - Crescendo bc3500
Subs - 4 sa 10 d1 spl's
Batt - 3 x 100 ah
149.5 Street beat
Integra Build Log
I use three ways to stick my part to be copied by the router. so here is one I came up with
use spray adhesive instead of nailing or using costly double stick tape
Spray it on
Heat it up
Before you use the router make sure you press hard or stand on your part so it doesn't seperate while using the flush trim router bit
use a paddle bit to get the router bit in there
make sure the bit and bearing is adjusted properly
now that all 16 8 inch Rockford Punch Pro rings are cut out time for the tweeters
The mini tower to the right is for Punch pro tweeters (super tweeters)
Yeah 5.25" outside diameter!!
