RickyFriery97 Posted September 3, 2011 Author Report Share Posted September 3, 2011 my lvl 5 smelled like glue when i played it hard first in the box, and i know for sure it wasnt hot, i could smell glue ish whenever it played low notes. (gain half of what it should have been at, and voltage steady at 13.6) yea at first i thought i may be glue, or the .5 ohm load. my voltage stays steady when im crusin Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 3, 2011 Report Share Posted September 3, 2011 Below tuning being the magic word. Or playing songs that are clipped themselves. i do play below tuning alot, mainly decaf songs though nothing to do with the low ohm load? No, ohm load won't make them stinky. You might not have enough electrical to support .5 ohms and cause the amp to clip but the ohm load itself won't cause stinky coils. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Torres Posted September 3, 2011 Report Share Posted September 3, 2011 voltage drop can play a role also, depending how severe it is. i think the low impedance would affect the amp before it would affect the sub. more heat put onto the components inside Quote Link to comment Share on other sites More sharing options...
Ray Posted September 3, 2011 Report Share Posted September 3, 2011 Below the f3 point is bad mmmmkay Not saying running at .5 is great but playing the lowzzz is prob doing more damage. Just make a box with a low f3 point and your golden Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
AA98hoe Posted September 3, 2011 Report Share Posted September 3, 2011 I can get my xls stinky real quick below tuning also with low voltage from clipping. But certain songs I can rail a full 3min song with no smell yea some songs i can play and not get stinky at all, i guess its those low songs I think your loving the sound of 1 and need at least 1 more to get your satisfaction. I have 4 and still want more Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
RickyFriery97 Posted September 3, 2011 Author Report Share Posted September 3, 2011 Below the f3 point is bad mmmmkay Not saying running at .5 is great but playing the lowzzz is prob doing more damage. Just make a box with a low f3 point and your golden F3 as in tuning correct ray? yea i dont like running that low, but is a D1 sub, may be switching to a T2500BDCP here soon though and will run @ 2 ohms my box is tuned to 32 right now, maybe ill hit ya up for a design Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
RickyFriery97 Posted September 3, 2011 Author Report Share Posted September 3, 2011 I can get my xls stinky real quick below tuning also with low voltage from clipping. But certain songs I can rail a full 3min song with no smell yea some songs i can play and not get stinky at all, i guess its those low songs I think your loving the sound of 1 and need at least 1 more to get your satisfaction. I have 4 and still want more i think your right, i want two in the tahoe, and either 4 18"s or 6 15"s walled behind the c pillar in my burb Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
RickyFriery97 Posted September 3, 2011 Author Report Share Posted September 3, 2011 Below tuning being the magic word. Or playing songs that are clipped themselves. i do play below tuning alot, mainly decaf songs though nothing to do with the low ohm load? No, ohm load won't make them stinky. You might not have enough electrical to support .5 ohms and cause the amp to clip but the ohm load itself won't cause stinky coils. good point, prob causing the amp to clip quicker the usual. Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
Ray Posted September 3, 2011 Report Share Posted September 3, 2011 Fb is the tuning freq. F3 is the point that the box is down 3db from its peak. F3 is where the sub will just see a hole in the box and start to lose control. Very bad to play down here. A good design can get you a f3 point well below the tuning freq(fb) A bad or poor design can actually have the f3 point above the fb. Crazy huh. I know. And yes i see it all the time. This is where using winisd or bbp6 is far better than just a volume calc. Live and learn Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
RickyFriery97 Posted September 3, 2011 Author Report Share Posted September 3, 2011 (edited) Fb is the tuning freq. F3 is the point that the box is down 3db from its peak. F3 is where the sub will just see a hole in the box and start to lose control. Very bad to play down here. A good design can get you a f3 point well below the tuning freq(fb) A bad or poor design can actually have the f3 point above the fb. Crazy huh. I know. And yes i see it all the time. This is where using winisd or bbp6 is far better than just a volume calc. Live and learn damn, learn something new everyday! now if i were to get a design from you for my XL 18", could you get it to where my F3 is well below my tuning? my box as of now i have no clue, cause i just used torres. or i could send you my dimensions and tell me what my FB and F3 is? Edited September 3, 2011 by RickyFriery97 Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
