DC Sound Lab
my lvl 5 smelled like glue when i played it hard first in the box, and i know for sure it wasnt hot, i could smell glue ish whenever it played low notes. (gain half of what it should have been at, and voltage steady at 13.6)
yea at first i thought i may be glue, or the .5 ohm load.
my voltage stays steady when im crusin
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Below tuning being the magic word.
Or playing songs that are clipped themselves.
i do play below tuning alot, mainly decaf songs though
nothing to do with the low ohm load?
No, ohm load won't make them stinky. You might not have enough electrical to support .5 ohms and cause the amp to clip but the ohm load itself won't cause stinky coils.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
voltage drop can play a role also, depending how severe it is. i think the low impedance would affect the amp before it would affect the sub. more heat put onto the components inside
Below the f3 point is bad mmmmkay
Not saying running at .5 is great but playing the lowzzz is prob doing more damage.
Just make a box with a low f3 point and your golden
I can get my xls stinky real quick below tuning also with low voltage from clipping. But certain songs I can rail a full 3min song with no smell
yea some songs i can play and not get stinky at all, i guess its those low songs
I think your loving the sound of 1 and need at least 1 more to get your satisfaction. I have 4 and still want more
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
F3 as in tuning correct ray?
yea i dont like running that low, but is a D1 sub, may be switching to a T2500BDCP here soon though and will run @ 2 ohms
my box is tuned to 32 right now, maybe ill hit ya up for a design
i think your right, i want two in the tahoe, and either 4 18"s or 6 15"s walled behind the c pillar in my burb :peepwall:
good point, prob causing the amp to clip quicker the usual.
Fb is the tuning freq.
F3 is the point that the box is down 3db from its peak.
F3 is where the sub will just see a hole in the box and start to lose control. Very bad to play down here. A good design can get you a f3 point well below the tuning freq(fb)
A bad or poor design can actually have the f3 point above the fb. Crazy huh. I know. And yes i see it all the time.
This is where using winisd or bbp6 is far better than just a volume calc.
Live and learn
Live and learn
damn, learn something new everyday!
now if i were to get a design from you for my XL 18", could you get it to where my F3 is well below my tuning? my box as of now i have no clue, cause i just used torres. :shrug:
or i could send you my dimensions and tell me what my FB and F3 is?
Edited by RickyFriery97
