Stinger voltmeter adjustment?
it was a waste of money to buy one than? you have to always change it than everyday?
Its better than nothing. For many people, being accurate to within .1-.2 of a volt is good enough. But there are better, more accurate meters out there.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
I have found with mine, you can have it within a tenth (.1v) one of two ways....
1} calibrate it for engine on voltage.
2} calibrate it for engine off voltage.
If you calibrate for engine on, voltage it reads engine off is up to +/- .4v
If you calibrate for engine off, voltage it reads engine on is up to +/- .4v
I like mine to be the most accurate engine on, so i calibrate mine as close as possible for that. When im in engine off senarios, I know the reading is off somewhat.
Mine however usually reads lower then actual engine off most times.
up
use the voltage reading at your amp(s), thats where you wanna watch your voltage
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
  • Who's Online   0 Members, 0 Anonymous, 1185 Guests (See full list)
