Stinger voltmeter adjustment?
Anyone got any good tips on how to adjust them? How much of was your guys one from the factory settings? I tried to set it today and it was only .1 off from the factory. idk will try again tomorrow. i using a dmm,but would a fluke mm be better? i did the big 3 and have a die hard platinum battery with a stock 80 alt. It sits at 13.6. Im thinking something wrong right now. maybe too small wire cause only running 8 gauge for my amp that has 600watts. i am gonna upgrade to 0 gauge with my new setup.
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
You have to calibrate the stinger meter. That's why you adjust it. Or else it may read 12 volts when it's actually 14 volts at the batteries.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
It is calibrated at the factory you normally won't have to adjust it, the last four I have installed were dead on to my fluke dmm.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
:WTFBubble:
why would you adjust volt meter?
Because I always want to think my 12 volt system is really 18 volts. MOOAARR POOOWWWWAAAA! Haha
Big 3 with Yellow Top
stinger meter sucks for accuracy. I checked against a calibrated power supply at work FRESH from the cal lab. and you can adjust at say 14.5 volts and then drop the voltage to 12v and it will be off .2-.3 volts. power supply is accurate to 1/1000th of a volt and double checked it with an agilent 6.5 digit meter.
DC.jpgDC POWER
  • Who's Online   0 Members, 0 Anonymous, 1901 Guests (See full list)
