kookz Posted September 9, 2011 Report Share Posted September 9, 2011 (edited) I have a stinger volt meter but where would be the best location to take the voltage from, i keep getting mixxed opinions and answers. I got a stock battery up front and an hc2000 in the back. At the amp? At the alt? at the front bat? at the rear bat? lmk opinions thanks Edited September 9, 2011 by kookz Quote Walled Police Interceptor Four 15s 160s Link to comment Share on other sites More sharing options...
zx10intn Posted September 9, 2011 Report Share Posted September 9, 2011 whichever you want the voltage to read from.... i run mine to the rear battery where my amp pulls from but i think its mostly preference Quote 1969 Chevy Chevelle 20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's Mechman 250amp cs144 alt w/AVBM Kinetik 1800 main battery/Kinetik 2400 in the trunk Pioneer AVH-3200dvd Headunit (2) sets of Hybrid Audio Technologies Imagine components up front (2) DD 3512's d4 coils Sundown sax100.4 component amp Sundown saz-3000d subwoofer amp 5ft^3 box tuned to 34hz MY BUILD Link to comment Share on other sites More sharing options...
armykyle1 Posted September 9, 2011 Report Share Posted September 9, 2011 I have a stinger volt meter but where would be the best location to take the voltage from, i keep getting mixxed opinions and answers. I got a stock battery up front and an hc2000 in the back. At the amp? At the alt? at the front bat? at the rear bat? lmk opinions thanks you bass amp or w/e draws the most current also put the meter to where its not up in your face cause they're funkin bright Quote TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting Link to comment Share on other sites More sharing options...
kookz Posted September 9, 2011 Author Report Share Posted September 9, 2011 whichever you want the voltage to read from.... i run mine to the rear battery where my amp pulls from but i think its mostly preference Ya i was thinkin rear battery aswell since thats closest to the amp Quote Walled Police Interceptor Four 15s 160s Link to comment Share on other sites More sharing options...
kookz Posted September 9, 2011 Author Report Share Posted September 9, 2011 I have a stinger volt meter but where would be the best location to take the voltage from, i keep getting mixxed opinions and answers. I got a stock battery up front and an hc2000 in the back. At the amp? At the alt? at the front bat? at the rear bat? lmk opinions thanks you bass amp or w/e draws the most current also put the meter to where its not up in your face cause they're funkin bright Im leaning towards the rear bat since its voltage is really close to what the amps getting Haha, the LED must be like the fucking aq bass knobs they are blinding. Im also thinking of running my remote line into my fuse box under my dash and fitting it into an accessory plug Quote Walled Police Interceptor Four 15s 160s Link to comment Share on other sites More sharing options...
BassMunky Posted September 9, 2011 Report Share Posted September 9, 2011 do it off the amp Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
durranic Posted September 9, 2011 Report Share Posted September 9, 2011 i have the same volt meter just never figured out where to mount it thats not ugly looking.. im wiring it to my buss bars.. Quote MURDERD HONDA PILOT! Link to comment Share on other sites More sharing options...
brownm3 Posted September 19, 2011 Report Share Posted September 19, 2011 From what I have read can’t you just install the volt meter to any 12v source (the front battery) just to get it working and take your reading from the source you want (the battery closet to the amplifier) and adjust the volt meter. From what I have read you will need to get a reading and have it adjusted anyways, so wouldn’t this method work to? Quote BrownM3 Build Log BrownM3's Youtube Channel "Csbrown147" My Official Feedback Thread (UBL) BrownM3 Jeep Build (UBL) Link to comment Share on other sites More sharing options...
AA98hoe Posted September 19, 2011 Report Share Posted September 19, 2011 Back battery or amp. My meter has saved me amps and subs. You want to know when your voltage is dropping dangerously low when playing fulltilt to turn it down. Don't demo at idle that's the worst Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
brownm3 Posted September 19, 2011 Report Share Posted September 19, 2011 (edited) Back battery or amp. My meter has saved me amps and subs. You want to know when your voltage is dropping dangerously low when playing fulltilt to turn it down. Don't demo at idle that's the worst Do you have your voltmeter running directly from your amp? Edited September 19, 2011 by brownm3 Quote BrownM3 Build Log BrownM3's Youtube Channel "Csbrown147" My Official Feedback Thread (UBL) BrownM3 Jeep Build (UBL) Link to comment Share on other sites More sharing options...
