Sorry forgot to post the budget like 400 or 500 whatever gets me an amp to power the 2 subs. Also whats wrong with the Aluminum coils compared to the copper. Aluminum coil subwoofer was suggested to me in my other thread but the original poster did not reply back I don't believe. I don't know the difference between the 2 could one please explain the sound difference?
Skar Audio SDR 10" x2 (Sealed Box)
Skar Audio 1500.1D (1 Ohm) x1
Skar Audio TX525c (Front with dash tweeter) x1
Kenwood Excelon KFC-X173 (Rear Coax) x1
JL Audio 360.4 (Mids & Highs Amp) x1
DEH80-PRS
XS Power d3400
Singer Alternator 275A
98 Jeep TJ 4.0 5 Speed
Crecendo BC2000! $340 shipped to your door, good customer service, good product. Very efficient (in my personal opinion), and it does rated.
So if I get the Crecendo BC2000 I would need to get 2 of them? Perfect its cheaper than the single AQ amp. Another question how would I hook 2 amps up to one deck as I have a separate amp for my speakers.
DEH80-PRS
XS Power d3400
So I have looked at some other amps and now I have even more questions sorry but I'm just still so new to this and I have searched around the forum and have found some minimal results. Okay, Lets say I purchased the HDC315 Copper Coil Subwoofer One 2 ohm Dual Voice Coil and wired it to 1 Ohm would AQ1200D Amplifier be able to power it without over powering it? It says the HDC315 can handle 1000 watts rms and at 1 channel the AQ1200D Amplifier outputs 1200 watts rms can it handle the over power? Also as said before I am purchasing two of the HDC315 could I hook up both amps to two separate speaker terminals? And have 2 amps power each woofer separately? Sounds stupid but then again I am still new to this all I'm not even sure if the AQ1200D Amplifier can be strapped or bridged or however it is called. Or should I wire it to a 2 ohm load or 1 ohm? Or should I wire it to a 0.5 ohm load with 2 speakers both dvc 2 ohm. And lastly Two 1 ohm Dual Voice Coil (DVC) Speakers into a 1 ohm load. I'm not sure what to do as I'm not sure what to do God I'm such a noob.
Now my other questions come in the form of Amplifier questions. Could these amps power the subs I'm buying to their utmost without blowing them? Also are they good candidates? Either for a 1 amplifier setup or dual amps. Looking for cost effective.
Hifonics Brutus BRZ2400.1D
Hifonics HFI2000D
Hifonics Brutus BRZ2100.1D
CADENCE TX-A1000D
Re Audio DTS-1500.1
Boston Acoustics GTA-1000M
DEH80-PRS
XS Power d3400
One quick question and it may sound stupid but not sure about this. Here we go... Lets say I have a 2000 watt rms 2 ohm mono amp and I wire Two 2 ohm Dual Voice Coil Speakers to a 2 ohm load does the amplifier recognize this and split the wattage evenly 1000 going to each sub or does the amp output 2000 to each sub. I know stupid question but I just wanna know before I try this out and either blow my amp or my subs or both.
DEH80-PRS
XS Power d3400
Can anyone help on my post #16? That would be most helpful.
DEH80-PRS
XS Power d3400
Would the Hifonics Brutus BRZ2400.1D or the AQ2200 be good for the subs I'm going to buy? I'm going to do the big three with a stock alt. I drive a jeep grand cherokee laredo 2000. I believe its a 132 amp alt... Also anyone answer my earlier post please?
DEH80-PRS
XS Power d3400
