so if you have a box built for say two twelves in a common chamber and you do a single port to one side will the sub closer to the port act different than the one further away??
No all subs should react the same as long as you dont wire them up wrong or their out of phase. What are the dimensions of the box and port?
Btw my all my ports are on one side of the box.:)
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
I'm assuming your worried about unloading, or am I misunderstanding the post?
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
i have three 12s and port on the same plain and i have unloading problems with the furthest sub from the port but its not to common for it to happen but my box is tuned to like 28 hz and is 50 inches long lol so i dont know depends on set up and variables like all vehicles and equipment , just stating my issue and that it is possible
2 12ks and i dont know what to do
build in the works!
That's the reason why people put 'loading walls' in their boxes. A simple board just behind the sub closest to the internal port opening can help direct the pressure so it's more evenly spread out between the subs. However, there needs to be enough room between the port opening and the loading wall so that the wall will not effect the box's tuning.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
alright that makes sense. so for this loading wall when you say behind the sub do you mean behind the motor? how do i determine which side is behind the sub? also how do you determine what is too close to the internal port? how do you know if one of the subs is unloading will it be moving more than the other? when designing a box is there any key give aways to determine if there will be any unloading issues? sorry for all the questions just trying to expand my understanding of enclosure designs
