subs burning and amp on fire
what is your voltage droping too? how much is your gain turned up IE 1/4, 1/2, 3/4 ?
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
how do i detect clipping.i only turn my deck up a quarter of the way. i dont have smd dd1 or nothing.it sounds clean, and my grounds are fine. ground from amp ground to chassis and from amp case to chassis.
wait what?????? elaborate on what you did please. your amp doesnt need an amp case to chassis ground. what made you think you needed one?
i have a metal case its just a secondary thing i do. and lpf.
Why would you ground the amp case?
Never heard that one before lol
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
If its only 1/8th thats very low.... I dont know man, check your wiring something is wrong...
Subs: 2 T1 12's
my brother taught me to do it. on a crunch amp i got from him, the board was mounted to the metal case (he took it apart and did it cuz it was supposed to help cool) and it never had a good ground, so i grounded case and worked fine from then on. so since then, ive done to all my amps.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
"bad wiring" you mean like grounding your amp case to the chassis? Just sayin
so far...
Why would you spray water on the subs? Why not the A/C or just about anything else?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
bogus...ok so the 2nd ground might be the problem?
and the amp originally had towo fans. 1 to blow in and 1 to blow out.the 1 that blows out doesnt work anymore.could that also make a prob?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
  • Who's Online   1 Member, 0 Anonymous, 1872 Guests (See full list)
