HPF makes my woofer very quiet
nitwimp
There in lies your problem. HPF will HPF all deck outputs(I believe). Therefore, when it is turned on, then it will affect your sub amp.
Unless the set of RCAs you use is for Sub only.
let say that he HAS 2 sets of preouts...one set for the front and one set for the rear speakers
so the thing is...why not sacrificing the rear speakers for the sub(you surely wont need rear speakers)?
in that case the HPF wont affect the sub
but it will affect the sub because its still a TRUE rear channel so the headunit WILL apply hpf settings to it NO MATTER WHAT...... ive been here done that on alot of h/u and there is no way around it..... either turn your hpf off or dont run a sub..... lol my 2 cents
realy?
so how am i playin my sub perfectly with the 2 sets of preouts on my alpine??
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
oh you should have 2 sets...at least
once again...what radio are you using??
jvc krd 620
Yes only one set of rcas going to my sub
you mean Jvc KD R620?
totally.
THEN.....CHECK these
it doesnt have a sub pre out...
but you can sacrifice your rear speakers for the sub....and the HPF wont affect the subs
it worked for me
++++it has 2 SETS of preouts
ill gladly sacrifice my rears for my sub. so just use the other set of preouts? finally something worth trying.
dont read! TRY it!
Make sure your sub is connected to the rear channels and turn on the sub output, that should let you now control the sub volume. If you mistakenly connected the subs to the fronts you aren't getting any signal to them.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
thanks god...finnaly there IS someone who knows l lil mor than the others
It's not that. You just didnt convey your idea properly IMO. "you can sacrifice your rears for the subs" isn't the same as switching your preout mode from rear to sub.
formerly known as Jaylor Swift
i agree 100%
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
realy?
maybe because its an alpine deck.... never owned alpine decks..... always tried it on shitty decks lol that could be the problem why i couldnt do it......
ps i dont like running subs on a sub/rear switchable deck....... sounds way different imo.....
/ LOL
big 3
Exactly. After looking at his deck specs, he can do this, which is what I was getting at and actually got at a few times. If his deck didn't have switchable RCAs, then HPF would still cause his problem.
I hope this is directed at me...
10501650_10203332501847103_1859383749711
Blown
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
