Decaf Posted September 24, 2011 Report Posted September 24, 2011 Bleh such a silly fault in such a specific area. you guys all use your hpf yes? part of making it souound good right? if u are using the headunit amp to power interiors, yes... it prevents damage and makes it sound better u can also use the deck/amp to get a custom slope. for example 80hz@-6db on headunit plus 80hz@-12db on amp equals 80hz@-18db
sayhuh? Posted September 24, 2011 Report Posted September 24, 2011 hmm... intresting....i always use hpf...but my mids and high amp is flat Well, my wife likes to get into the car and touch stuff, so I set it all flat and this way if she touches anything, then it is more of a no harm no foul...fail safe if you will lol. Blown
deeje Posted September 24, 2011 Report Posted September 24, 2011 Bass cant move from -6. Isn't the bass setting on most decks(at least everyone ive seen) control the door speakers bass? The subwoofer level controls the actual sub bass. --2004 Toyota 4runner New Build Log -2002 Acura Tl-S Old Build Log Team DC Audio spl dust is an option you can get on the coils... it's great for extra 1000 watts of power where can i get this spl dust and how much is it. is it hard to apply? lol
Decaf Posted September 24, 2011 Report Posted September 24, 2011 Bass cant move from -6. Isn't the bass setting on most decks(at least everyone ive seen) control the door speakers bass? The subwoofer level controls the actual sub bass. correct. i stated that already. bass level changes 60/80/100/200hz sub level changes everything below the LPF setting (should be set at 85)
nitwimp Posted September 24, 2011 Author Report Posted September 24, 2011 Bass cant move from -6. Isn't the bass setting on most decks(at least everyone ive seen) control the door speakers bass? The subwoofer level controls the actual sub bass. correct. i stated that already. bass level changes 60/80/100/200hz sub level changes everything below the LPF setting (should be set at 85) Well if thats the case then everything is fine.... if i want more i should adjust the bass eq? but i thought pumping that up is bad
Decaf Posted September 24, 2011 Report Posted September 24, 2011 Bass cant move from -6. Isn't the bass setting on most decks(at least everyone ive seen) control the door speakers bass? The subwoofer level controls the actual sub bass. correct. i stated that already. bass level changes 60/80/100/200hz sub level changes everything below the LPF setting (should be set at 85) Well if thats the case then everything is fine.... if i want more i should adjust the bass eq? but i thought pumping that up is bad so if you turn the HPF off... does the bass level go to 0? if u want more bass u either need to turn the headunit up more, turn the gain up more... or different subs/box/bigger amp. an eq should not be used to boost what is lacking... its best used to quiet whats too loud
gally Posted September 24, 2011 Report Posted September 24, 2011 hmm... intresting....i always use hpf...but my mids and high amp is flat Well, my wife likes to get into the car and touch stuff, so I set it all flat and this way if she touches anything, then it is more of a no harm no foul...fail safe if you will lol. X2 on that....but in my place is not the wife but is the father...(mine of course) 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
nitwimp Posted September 24, 2011 Author Report Posted September 24, 2011 Bass cant move from -6. Isn't the bass setting on most decks(at least everyone ive seen) control the door speakers bass? The subwoofer level controls the actual sub bass. correct. i stated that already. bass level changes 60/80/100/200hz sub level changes everything below the LPF setting (should be set at 85) Well if thats the case then everything is fine.... if i want more i should adjust the bass eq? but i thought pumping that up is bad so if you turn the HPF off... does the bass level go to 0? if u want more bass u either need to turn the headunit up more, turn the gain up more... or different subs/box/bigger amp. an eq should not be used to boost what is lacking... its best used to quiet whats too loud If i turn the hpf off i am free to adjust the bass from -6 to +6 and the hz but with it on it is stuck at -6 and 60
Purplehaze Posted September 24, 2011 Report Posted September 24, 2011 Read my post above. If you have only two sets of RCAs, then you cannot use HPF because it will HPF all sets of RCAs. If you have 3 sets of RCAs, make sure the sub set it running to the sub amp and make sure the sub setting is set correctly. Also, the sub out RCA's may be 2 separate mono sub out lines, and could be trying to use them as one stereo line out??? Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
deeje Posted September 24, 2011 Report Posted September 24, 2011 Bass cant move from -6. Isn't the bass setting on most decks(at least everyone ive seen) control the door speakers bass? The subwoofer level controls the actual sub bass. correct. i stated that already. bass level changes 60/80/100/200hz sub level changes everything below the LPF setting (should be set at 85) my bad there's so many posts I must have missed it. --2004 Toyota 4runner New Build Log -2002 Acura Tl-S Old Build Log Team DC Audio spl dust is an option you can get on the coils... it's great for extra 1000 watts of power where can i get this spl dust and how much is it. is it hard to apply? lol
