HPF makes my woofer very quiet
nitwimp
Set the gain on the amp about half way up, make sure you turn off any type of filtering on the amp and that should get you something coming out of them, if not then the amp is not powerful enough or your wired to a higher ohm load then your thinking.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
no success with trying different preouts
any body else have any ideas, maybe new head unit? ugh..
You have to change your deck settings too. Change your rear preamps to Sub preamps.
this. then a subwoofer level control will be available in the settings also along with a LPF for the subwoofer. i think its 0-8.
2.5V/4CH Preamp Output: The KD-R620 is equipped with two pair of 2.5V preamp outputs (Front, Rear/SW). You can set the Rear/SW preamp outputs for connecting a pair of full-range rear speakers (through an external amplifier) or for connecting a subwoofer (through an external amplifier). When set for rear speakers, the rear outputs operate with the unit's fader control. When set for subwoofer, the outputs are non-fading.
Built-in Crossovers: The JVC KD-R620 features a built-in high-pass filter for the unit's front & rear speakers and a low-pass filter for the unit's subwoofer output.
High-Pass Filter: You can activate a high-pass filter (fixed) for the unit's front & rear channels (speaker- or preamp-level), so low frequency signals are cut off from your system's front & rear speakers.
Low-Pass Filter: When the unit's Rear/SW preamp output is set to Subwoofer, you can set the cutoff frequency of the low-pass filter at 55Hz, 85Hz, or 120Hz.
Subwoofer Level: When the unit's Rear/SW preamp output is set to Subwoofer, you can adjust the head unit's subwoofer level between 0 and 8.
thanks god...finnaly there IS someone who knows l lil mor than the others
I hope this is directed at me...
umm....no sayhuh...that is not directed to you..
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
Yes correct i am able to adjust the subwoofer level but i am not able to adjust the bass level. it is stuck at -6. this is my problem. i had my stuff plugged in right the first time.
http://resources.jvc.com/Resources/00/01/49/70.PDF
this is the user manual for your radio the kd r620
it has the front preout and the rear/subwoofer selectable preout...
switch your rear speaker preout to your subwoofer preference preout
Go to menu and look for pro eq then L/O mode and switch it to SUBW.
totally, and its working. but i still cant adjust the bass. i can adjust subwoofer level but not bass. bass is stuck at -6.
do u have eq on user?
bass is for 60hz/80hz/100hz/200hz and above and will affect ur interiors more than the sub... ideally it shouldnt be boosted much if any
  • Who's Online   0 Members, 0 Anonymous, 969 Guests (See full list)
