Zingers Posted September 24, 2011 Report Posted September 24, 2011 What would be the best bet to stop the vlotage drop? when i'm Bumping pretty good my headlights Dim and my gagues drop down and jump back up. so what would the best bet be battery or capacitor? what i'm runing Performance teknique 1500 watt(subs) Performance teknique 600 wat(mids/highs) Pioneer DEH-3300UB pioneer Mids/highs sub Woofers 2 Kicker CVR i'm a Quote
CHEVY4X4BLAZER Posted September 24, 2011 Report Posted September 24, 2011 Snafu said capacitors work. PERIOD. Quote
Hotdog Posted September 24, 2011 Report Posted September 24, 2011 Battery Quote (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Watch the bass Posted September 24, 2011 Report Posted September 24, 2011 Battery, a capacitator will strain your electrical system. A capacitators give a first time a quick support to your electrical system, but from than your system have to fill the capacitator up again and agian and again, it hurts more than i works good. Capacitators was an idea of the past in caraudio. But other question, did you have done the Big 3 upgrade? The "one" of easy/cheaper upgrades for the electrical system. Quote "in the abundance of water, the fool is thirsty" Bob Marley
techforce Posted September 24, 2011 Report Posted September 24, 2011 capacitors are good for voltage drop only if you have a strong enough alternator to keep up with it and your system... It sounds like the alt doesnt... I would say a battery close to the back would help best... Quote
HazeGrey75 Posted September 24, 2011 Report Posted September 24, 2011 There is no replacement for a alternator. A extra battery will only help keep your amp alive a few minutes long as it kills your stock alternator. Quote
CHEVY4X4BLAZER Posted September 24, 2011 Report Posted September 24, 2011 Battery, a capacitator will strain your electrical system. A capacitators give a first time a quick support to your electrical system, but from than your system have to fill the capacitator up again and agian and again, it hurts more than i works good. Capacitators was an idea of the past in caraudio. But other question, did you have done the Big 3 upgrade? The "one" of easy/cheaper upgrades for the electrical system. Once the vehicle is running, the battery also becomes a load on the alternator. Quote
97SSBlazer Posted September 24, 2011 Report Posted September 24, 2011 There is no real "fix" without buying an after market alt. Batterys will help UNTIL THEY DIE. If your alt doesnt have enough to rechage them then they arent really doing anything.... Quote lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/
shogen Posted September 24, 2011 Report Posted September 24, 2011 Battery, a capacitator will strain your electrical system. A capacitators give a first time a quick support to your electrical system, but from than your system have to fill the capacitator up again and agian and again, it hurts more than i works good. Capacitators was an idea of the past in caraudio. But other question, did you have done the Big 3 upgrade? The "one" of easy/cheaper upgrades for the electrical system. Once the vehicle is running, the battery also becomes a load on the alternator. There is no real "fix" without buying an after market alt. Batterys will help UNTIL THEY DIE. If your alt doesnt have enough to rechage them then they arent really doing anything.... again, no substitute for a stronger alternator.. But a second battery is waaaay better than any capacitor I've come across... Quote Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Zingers Posted September 25, 2011 Author Report Posted September 25, 2011 (edited) so if i was to get a better alt u think i would be good with out a second battery and/or capacitor? i have not done the big 3 upgrade yet but hopefully i will do that soon i metered my battery and i get 14volts and it drops down to 11-12volts when my subs hit (stock alt) Edited September 25, 2011 by Zingers Quote
