i am going to build a new setup and rite now im running 7 of the 16v kinetiks i have already upgraded my alt. with ext. reg. my setup now is only for spl but my new one i want to street beat. what is the best for street beat 12v 14v or 16v? i have been looking at the xs power 14volt batteries just don't know if i should keep my 16v kinetiks and run off the 12v post for street beat or look into the xs power 14v
If you already have 16v batteries why wouldnt you just stay at 16v?.....
Big 3 with Yellow Top
isn't there step down module you can hook up to alternator and run to 12v battery? i would stick with 16v system since you already have HO alt and batts
x2. That would be smart to just have your system at 16v and you car off the step down at 12v
isnt there an xs batt with 16 volt 1 side and 12 theother?
maybe one of them could help you
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
I think you have XS confused with Kinetik
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
What they've already said, step downs is the way to go since you are already vested in 16v batts.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Woody, kinetic has the 12v post, not xs. With xs batteries, you'd had to run step-downs. Here's the issue though, the higher you go up in voltage (from 14 to 18v I.e.) the less capacity batteries will have. Like the xs d3109 is good for around 5k watts of power, whereas I believe their 16v d1600 is only around 2500. One alt is the limiting factor and the more and more power you add the more batteries you will need. Remember, although you're charging at around 18.8v, 3 or 4 volts of drop is still just as bad as 3 or 4 volts of drop at 12.
Wouldn't the drop In theb12v setup be worst because your dropping to 11 or so where as with the 16v would drop to about 15-16v or so in your example.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
