Do the (4) Rockfords on the (2) JL amps, if you need a box design let me know. But just to make sure the Fosgates are the same ones right? And to answer your other questions a little more clearly, you run into interference between subs when you mix brands or sizes just for the simple fact that they are different in every way (usually, might sometimes be one or two things in common). One JL amp is probably more powerful than your BOSS so jump on those two if you can. And the boxes you are showing pictures of are special styles of boxes called bandpass (i think one was 4th order and the other was quasi 6th) either way starting out you would probably be better off with a plane jane simple ported box. And speakers (mids/highs) typically are fine to mix brands (preferably all the same but its not bad as subs since speakers are usually far apart) just always do regular speakers in pairs. Again if you have any questions PM me i would be glad to help.
thanks. and yes they are the same subs
Ok then ya do that you should be gtg. Although with the two JL amps you may want to look at do 0ga to the back and then a 4ga run going to either amp from a distrobution block.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
After reading this thread, im glad you finaly listened to what everyone had to offer. Good to see new people into car audio. Keep up the work and listen to what people have to say. You will lear a lot here as long as you listen. Hope so see some pics of your build when you get it all done.
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
is that somthing i NEED to do right away? or would it be ok to keep the 4g for a lil bit till i get more money
May I add that I noticed you said you're jobless right? You may want to be careful with getting into car audio believe me a lot of random ish happens in this game and when those problems reach you, you don't want to be stuck without a car to drive. Also remember I am pretty sure all of us here has either received or been close to receiving a ticket for being too loud (noice violations are bitch) I have gotten a few I take them in stride but someone without a job might not be too accepting of one...just saying. Know what you're getting into before you jump head first. I noticed everyone failed to ask the question can that truck even handle the power you're throwing at it?
im not going to be getting a ticket cause i dont drive this on the streets yet lol..its just an offroad truck till i get insurence
and why wouldnt it be able to handle the power?
ive got a high output alt and two batteries
is that not enough?
Technically yes it is more than enough for what you doing but that does not mean problems will not arise...in the game of life always remember, shit happens...lol. Since you said this isn't your daily driver or your means of transportation then by all means guinea pig that bish learn all you can now, trial and error then when you get it on the road its a beast. Good luck with your build if you have any questions at all let me know.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Ported and Sealed is totally dependent on the person and their listening habits. For most they go ported so they can tune their boxes to exact preference. I have a ported on my SPL build but I am going sealed for my SQ build in my Civic I like sealed because I don't lose any notes but if you want to get low and loud ported all day. For someone just getting into systems I would advise sealed its easier and you can always change it later and subs firing up is usually the suggestion in hatchbacks and SUV's.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
so just a simple square box built to the correct air volume all four firing up is the way to go?
Dude, just build a ported box. There are plenty of people here to help, even some with the same truck.
Big sealed box for multiple woofers in an suv? :No:
Have you finalized your decision on the subs you'll be using? And whats the max space you have in the back of the truck?
SMD Super Seller
My Feedback Thread
im gonna use four fosgate hx2s
and its about its just under 3' deep and 3.5' wide
