okay i just now got my dd1 today and 1st thing i did was start tuning went to the store bought my 9v battery, got back i already know from twistedchild420 video on everything flat my headunit clips at 37 so i put it on 37 tuned my strapped aq3500d1 and i did it how it said stoped it before it said distortion, (used track 7 to set my gains) got everything done went really fast to a park to play it really fast played bass ballin and i dont drop below 13.2volts on full tilt but on certain notes my gainknob says that im on a hard clip? and i can feel my woofers getting hot and can smell some coil as well???
well what could my problem be? i use to be able to play it for awhile until it started doing that am i doing it incorrectly? or maybe my woofers cant take so much power? its wired pretty high?(yes i am going my rms on my woofers)
well anyways here it goes on gear
hu pioneer avh 3200dvd
amps 2 aq3500d1
woofers 2 dc audio xl 15
help please
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Posted (edited)
how new are your subs? did you check to make sure that your H/U distorts are 37? Just because his did doesn't mean yours will.
oh yeah plus
Is track 7 the -10db one? Use the -5db track, especially if you play 'loud' bass songs.
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
okay ken i will try that man hopfully that works i wasnt aware of that i just wanted to be louder
oh yeah plus
i believe brian reconed these maybe a month ago give or take, but is all headunit differnet? me and him have the same headunit they will clip in different volumes?
Sounds like your amps distortion point is higher than your subs power handling capabilities. Did you turn your gain UP from where you had it after using the DD-1?
no i didnt not re-adjust anything as of now the amp is still how it is from the dd1 is tuned too
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
when it says -5, do u leave the bass at -5?
what do you mean the bass at -5? where can i find that on the headunit?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Don't worry about that right now.
gimme a quick sec on going to readjust it with the lower one
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • Who's Online   0 Members, 0 Anonymous, 678 Guests (See full list)
