dereko2 Posted October 5, 2011 Report Share Posted October 5, 2011 When I'm listening to a bass boosted song. It happens randomly it shuts off for about a second or two but comes back. I have a capacitor but i think it's dying cause it on read "9 voltage" when playing a song. Do anyone knows about this problem. My amp is DLS ultimate a6 My sub Kicker Solo Baric L7 15" Thank you. Quote Link to comment Share on other sites More sharing options...
Arsenal96 Posted October 5, 2011 Report Share Posted October 5, 2011 Im not a expert on voltage but im pretty sure that when it reads 9 volts that is NOT good haha Quote Link to comment Share on other sites More sharing options...
CHEVY4X4BLAZER Posted October 5, 2011 Report Share Posted October 5, 2011 If you're reading 9 volts then your alternator is dead and your battery is not far behind. Quote Link to comment Share on other sites More sharing options...
infamous360 Posted October 5, 2011 Report Share Posted October 5, 2011 Im not a expert on voltage but im pretty sure that when it reads 9 volts that is NOT good haha its reading 9volts? take the cap out and play a little bit without it. Possibly get a new battery or alternator too... 9volts is WAY to low. O_o Quote AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener Link to comment Share on other sites More sharing options...
Punkeyboozter Posted October 5, 2011 Report Share Posted October 5, 2011 does it read 9v when you jam out or when the car is just idling along? If it is while you are playing your system you are under vol-ting your amp which will lead to it blowing up. Getting rid of the cap is a good start adding another battery or maybe even a upgraded alt, even better. Quote Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice. Build Log>>> http://www.stevemeadedesigns.com/board/ind...pid=672024& New Build Believe in the order Link to comment Share on other sites More sharing options...
new guy Posted October 5, 2011 Report Share Posted October 5, 2011 Jesus 9 volts with Just 1 l7? I bet it's the cap. With my l7 even if I were trying I don't think I could get it that low and ihave completely stock electrical Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit Link to comment Share on other sites More sharing options...
mbdblue Posted October 5, 2011 Report Share Posted October 5, 2011 does it read 9v when you jam out or when the car is just idling along? If it is while you are playing your system you are under vol-ting your amp which will lead to it blowing up. Getting rid of the cap is a good start adding another battery or maybe even a upgraded alt, even better. come on now sounds like you have some testing to do. DDM at the battery, alternator, and amp. no voltage should be that low. Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
Punkeyboozter Posted October 5, 2011 Report Share Posted October 5, 2011 does it read 9v when you jam out or when the car is just idling along? If it is while you are playing your system you are under vol-ting your amp which will lead to it blowing up. Getting rid of the cap is a good start adding another battery or maybe even a upgraded alt, even better. come on now sounds like you have some testing to do. DDM at the battery, alternator, and amp. no voltage should be that low. it should not be be, but it can easily happen. Quote Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice. Build Log>>> http://www.stevemeadedesigns.com/board/ind...pid=672024& New Build Believe in the order Link to comment Share on other sites More sharing options...
TeamHT Posted October 5, 2011 Report Share Posted October 5, 2011 Jesus 9 volts with Just 1 l7? I bet it's the cap. With my l7 even if I were trying I don't think I could get it that low and ihave completely stock electrical The sub isn't what is drawing current. Quote Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
dereko2 Posted October 6, 2011 Author Report Share Posted October 6, 2011 it only read 9v when i'm playing music with superb bass boosted song. So the low voltage causes the bass pause for about 1-2 seconds? Ok I should replace my cap. Thank you guys. BTW. What volt it should be reading? 12? 14? Quote Link to comment Share on other sites More sharing options...
