Speakers pop when truck turns off
I have a 2004 silverado with 4 kicker amps, and hella speakers. Whenever I turn off the truck, all the highs make a super loud pop. I know on older gms if the illumination is hooked up it can cause that, but not in all models. Im not sure if thats the case in 2002+ gms. I have an older kenwood indash that has a brain hidden somewhere in the truck, so its not as easy as just pulling the deck to check for a wire. Im wondering of other things to try before I rip it appart. the grounds look good, so I dont know..... Help?
Gary 'Numatik' Eberle
West Sacramento, California
Vehicle build log (1) 'Aayla' Numatik's one and only, bodydropped pasted the doors Chevy S-20 Ext-Ext cab. This project ended after a horrible horrible motorcycle accident. There are so many mods it would fill an entire page in my sig. Check it out if you have A LOT of time to kill. http://www.stevemeadedesigns.com/board/topic/39785-numatiks-doored-s-20-bodydropped-on-doors-ext-ext-cab-10-subs-full-frame-build/?hl=%20numatik#39;s
Vehicle build log (2) 'Snow White' Daily/showstopper 2004 Chevy Silverado
Lays on 22s soon for 26s to run a beefy tire on 4s (4) 5gal tanks, (3)AZOB2 pumps, Slam digital stealth two speed valves with 16 solenoids, Slam SS bags all around, ART upper and lower arms, KP Components 6-link, KP Components watts link, Panther juice 6 22s, Spikes EVERYWHERE. 3,600WRMS total, (5) Kicker amps, (2) L7 15s under raised back seats, 15" screen molded to dash, 36 speakers total all Mb Quartz and Fosgate. Fiberglass console with removable face plates and arm rests, flushed speakers, lots of toggle switches, Playstation 2, rear view camera, Suede and leather seats, suede headliner, Dakota Digital air gauges, voltage gauges, and current draw gauges. (2) XS Power 4800 batteries, Whole truck is flat black and white and the
ENTIRE truck is fully pin striped by TJ Pagano here in Sacramento.
http://www.stevemeadedesigns.com/board/topic/123328-numatiks-bagged-2004-silverado/
"What doesn't kill you makes you stronger. I am proof" - Numatik
Something similar happened to my buddy's system, the subs would make a loud "thump" noise when we turned car on or off, so we added a high-low instead of the outputs on the stereo & it got rid of the sound. shrug.gif
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
Mine its all the highs popping, but I have an indash so no need for a high low.... there must be another way. 2marro im probably gonna start tearing it appart to see if its that damn illumination wire.... but theres a good chance that has nothing to do with it. In some older gms it dosnt matter, and others it does, but this is a newer truck so i dunno..... :nea:
I had this problem before check your RCA's, y-spliters and grounds
@DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many
-TEAM WOBBLY WOOFERS-
4 18s MAKE YOU SCREAM!
I have already checked the different rcas and they were fine. Im going to try this http://www.darvex.com/store/pc/Stinger-Amplifier-Pop-Stopper-55p9.htm
that will work . i have the rca ground isolator RCA buy stinger and works like a charm . good luck buddy :)
my car use to have a whisle in the tweets wen u reved the engine and that fixed it:P
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
:drinks: Should fix it :good:
try hooking remote wire to a different circuit you wont need that little device...
NISSAN SKYLINE GTR R32 (Build in progress)Fosgate POWERhttp://www.stevemead...-fosgate-power/--------------------------------------------------------------------97 Honda AccordRockford Fosgate1400 watts RMS totalhttp://www.stevemead...e-1400watt-rms/---------------------------------------------------------------------
I already rewired the remote wire to a relay on 15 amps for the 4 amplifiers. Also the stinger pop stopper didnt fix it so I returned it. It has to be an RCA with a bad connection somewhere, theres alot of problems with the wiring of this system, in time im going to have to rip it all out and do it myself so I know its perfect
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
