i have someone willing to trade me a R1000-1D for my hifonics brz-1200d. but i was looking at there specs on sonicelectronix and the hifonics has a better signal to noise, less thd at rated rms, and the hifonics has a subsonic the fosgate doesnt. would those things affect much? i thought fosgate was spouse to make really amazing amps? should i still go with the fosgate? i need 1000 at 2 ohms witch the fosgate gives but the hifonics only gives 900 rms. which do you think would be better for me?
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
im pushing a kicker l7 15" with it btw
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
its a brz so it should do its rated power so if you trade ur getting screwed @ 1ohm out of 200 watts...but if the RF gives you 100 more watts @2ohm its a tough call.RF i think cost more.but the hifonics amps do sound really clean...i love hifonics amps personally so im gonna say keep the hifonics
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
yeah thats what i was thinking. the reason i wanted to trade is im pretty sure the fosgate will be more efficient and if i ever want to upgrade i could probably sell the fosgate for more but another thing is if i trade for the fosgate the guy doesnt have a bass remote. which idk if i really need cus my hu has a sub control.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
in my opinion i would go with the fosgate. they been around along time and they are a solid product. as for bassknob those are cheap on ebay besides your getting more power out of the fosgate =] but its up to you good luck
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
I'd trade it for the rf
Bass knobs r easy to come by for it
stevemeadedesigns.com/board/topic/105505-silvia-first-time-build-kenwood/
hmmm id like to get the fosgate but the signal to noise ratio,thd and no subsonic worrys me. can i get some input from anyone whos used this amp before on how good it sounds.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
i would go with the hifonics. the rockford is part of the rockford prime series which is the bottom end line
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
^^this
Your hifonics is actually probably higher quality, from what I've seen the RF prime series isn't anything special. Plus don't worry about the 100 watts, on a daily set up that isn't even an audible difference, and to be honest probably isn't a difference at all.
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Has anyone acually used the fosgate before?
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
