has anyone put an after market head unit into a 99 ford taurus?
I looked and looked and none of the wiring diagrams matched this car.. so I found the constant and the ground and put the head unit in.. then I couldn't find the remote.. so I wired the remote wire form the radio to the constant for the time being... then I turned on the radio and started putting speaker wires together... the radio is on.. but no sound will come form any speaker.. fml
I had the same problem! I actually bought the amp bypass wiring harness, and hooked all my speaker wires up that way.
If you have the digital climate control, you must keep it plugged to the factory and then run wires from your constant and ground from there to the harness, then locate the yellow/black stripe wire, which is your ignition! It should turn on and off with no issue now!
You must buy the amp bypass harness in these cars, they are a pain in the ass!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
it might have a factory amp i have done a few Taurus's (as far as mechanics go i am the Taurus king i have been told...lol) what i usually do that is easiest is just run my own speaker wire. you can go thro the factory door looms but its a b**ch. only way to get it to work is to hook up the factory radio and get a test light and go on each wire to see if it has power cut any wire that does and rewire each time and when u get no sound but everything works on the radio i would say u have the factory remote wire...then u wire that to ur head unit remote wire and you should be in business...this way works i could never find a good wiring diagram of the Taurus radio ....hope this helps
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
doesnt this have the amp in the trunk and require the long ass harness. funny dash kit all that stuff.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you can.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i have a 2001 Taurus 160$ just for the dashkit.
what i did before is just run my power and ground for my hu straight to the battery. then hook up some speaker wire to both the ignition and constant so when i touched the ends it turned on. i just had the hu on the floor lmao it was ghetto as hell.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
Look on ebay you can get the harness and dash kit for like $50-$60! Trust me its worth it in the long run, to run wires through the doors is a pain due to the clip in the door jam! Trust me been there done that!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
