Lol I just know Higher volt pre outs = good
Pioneer deh-8300UB
6- Image Dynamics CSX6.5v2
4-Image Dynamics XS-28 tweeters
4-Sundown Audio sa8v2's
1-Sundown Audio SAX-200.4
1-Sundown Audio SAX-1200d
1-Mechman 270a alternator
1-XS Power D3400 under hood
Second Skin Damplifier Pro Deadener
Kicker & Knukoncept 1/0 wiring
Big 3 upgrade
Not always the case though.
I'd rather a deck that outputs a good signal with a low voltage than a high powered one with a crap signal.
If Pyle came out with a radio that had 8v preouts, would you buy it over one of Alpine's 2v decks?
An issue with high voltage headunits is not all amps go high enough to match. If your deck is 5v and the amp with the gain all the way down is 2v for example, you'll clip when you turn up the volume.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
What about the hu I'm getting?? Is it good? No clipping? I'm using a apsm-1300
You'll be fine as long as you properly set the gain.
Basically what I'm describing is the exact same thing that happens when you turn the gain up too high. Its just in this case you can't get the gain low enough.
You can clip virtually ANYTHING if you're a dumbass with gain settings.
Edited by BJD3
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
4v pre-outs just mean you don't turn you gains up as much to match your head unit . At least that's my understanding.
Your subwoofer amp gets a stronger input so it doesn't have to be turned up as high to meet the same output. Allows for more power with a lowered chance for clipping because you're not stressing the amp as hard.
Lol, more power from higher input voltage. If that was true we would all use a line driver and boost it to 10 volt. The amp isnt stressed more when turning up the gain and keeping wattage equal.
Well I gave it a shot... Disregard what I said pit bull. It was not my intention to give you bad info. My bad. And pyle is exactly that a Pyle of shit IMO. But anyway get the DD-1 to set your gains and you can't go wrong.
Pioneer deh-8300UB
Big 3 upgrade
